Home > Wheels & Tyres > Headache!
GARYF123
Headache!
My 2007 2.7 TDV6 came with 22" aftermarket rims. I managed to get hold of a set of 20" 7 spoke genuine Land Rover rims fitted with GG AT 275 x 45 x 20" tyres. I have resprayed and lacquered them and fitted new centres and tried to fit them yesterday but found that the wheel nuts wouldn't fit. This morning, I did a 40 mile trip to get some new ones and got down to fitting them - won't fit!!! Diameter clears the brembos but the back of the mounting face doesn't seat against the hub as the back of the spoke hits the brembos! The details on the back of the new rims are EH2 IS58 which I assume is 58 mm offset,
8.1/2J x 20, RRC503050XXX, LRO2 925Kg.
Is the solution as simple as fitting wheel spacers? If so, what size and will it affect geometry etc?
Many thanks in advance,
Gary.
Post #548939 Sat Feb 17 2018 3:14pm
geoffsnook
Did not think the tdv6 hse came with brembo's as standard but may be wrong do the back wheels fit ok or is it just the front that you are having the trouble with Thumbs Up
Post #548948 Sat Feb 17 2018 4:04pm
GARYF123
Hi Geoff, thanks for prompt reply,
Not got round to trying rears. From a little bit more investigation, it seems that in order for the back of rim to clear caliper (with the mounting face of rim tight up to hub mounting face) it would need approx' 14mm spacer on each side. But, this would then lose the 72mm ish diameter hub mounting flange! Or, does the new spacer have a 72mm flange to mount wheel on?
Gary.
Post #548951 Sat Feb 17 2018 4:16pm
geoffsnook
It should be the same size as the hub Thumbs Up
Post #548954 Sat Feb 17 2018 4:25pm
GARYF123
Hi Geoff,
If i got 20mm spacers to be on safe side, would i have to put on rears too? (i expect so) and will i need to get suspension aligned/geometry checked or is the extra 40mm width negligible?
Gary.
Post #548957 Sat Feb 17 2018 4:51pm
Hog
Netherlands 2012 Range Rover Sport SDV6 HSE Lux Buckingham Blue
it will probably effect your camber setting RRS 3.0 SDV6 HSE Lux
RRS 3.0 TDV6 gone
LR 3 HSE V8 gone
DiscoveryII V8 Gone
Discovery 1 V8 Gone
Mustang Shelby
Alfa Guilia (classic)
Post #548958 Sat Feb 17 2018 5:28pm
geoffsnook
Yes front and rears it will be worth having it checked after Thumbs Up
Post #548962 Sat Feb 17 2018 6:11pm
GARYF123
Just a couple more questions re spacers!
Would the 20mm wide spacer just fit on hub mounting face, then wheel mounted and original flanged wheel bolt fitted (would original stud be long enough?)
Or, would extended studs have to be fitted and cut down to length.
Or, wound spacers have to have mounted on existing wheel studs and clamped with new short nuts, then wheel mounted in new studs pressed into spacer?
Sorry for my ignorance!
Gary.
Post #548986 Sat Feb 17 2018 10:04pm
Not that it matters as the wheel P.C.D are all the same, but just as a point of interest possibly, that particular rim was only ever fitted to the 2002-2009 Fullfat R/R.
Post #548991 Sat Feb 17 2018 10:47pm
