Home > Technical > Intake Manifold Repair
DSJ
I believe I have a crack on the intake manifold - is this something that can be repaired with some kind of sealant/glue/compound like another member on this forum has?
Post #544204 Thu Dec 28 2017 10:02am
Sharpy1980
United Kingdom 2007 Range Rover Sport TDV8 HSE Zermatt Silver
It’s worth a try just make sure you use a 2 part epoxy resin like araldite or gorilla glue and clean the crack and surrounding area with brake cleaner and the give it a good rough up, you could even try and weld the crack back together first with a soldering iron and cover with resin just be careful not to make any holes as you don’t want any lumps of dried glue inside the intake,
I also would ignore the claims that it sets in 5 mins but allow 24 hours if you can to make sure it’s fully cured Clickadeeclick
Post #544206 Thu Dec 28 2017 10:15am
DSJ
will the manifold have to be completely removed?
in the interim, i have just read that as there is a TSB for it, this can be taken to the dealer and repaired free of cost as it is an inherent manufacturing fault to due the thickness of the plastic.
any thoughts on this?
Post #544208 Thu Dec 28 2017 10:18am
Sharpy1980
That would depend on where the crack is but if you have to remove the manifold I would sooner replace it rather than repair if it were mine,
It’s got to be worth a phone call to the dealers first as once you try and repair it they won’t entertain doing it free, try a few different dealers but your service history can be a factor in goodwill claims Clickadeeclick
Post #544210 Thu Dec 28 2017 10:23am
Disco_Mikey
Warranty on a 7yr old car? Can only ask...
The new manifolds are a stronger design, and won't split again. Not that expensive either, in the grand scheme...
Post #544211 Thu Dec 28 2017 10:25am
DSJ
how do i avoid any lumps of dried glue inside the intake?
will this be covered under a warranty by warranty direct?
Post #544213 Thu Dec 28 2017 10:28am
DSJ
just spoke to dealer, they will firstly carry out diagnostic at £152 per hour even though fault is visually obvious.
then they will see if i meet certain criteria i.e. service history, previous cars purchased etc.
they said it is up to managers discretion
anyone had any experience with this being successful on 7 yr old car?
Post #544217 Thu Dec 28 2017 10:55am
Sharpy1980
Epoxy is quite thick so won’t run through the crack unless there’s holes, as for warranty direct I would have thought it will be covered as it can hardly be regarded as wear & tear but then you never know, I’m sure if you get a written quote from an Indy you can present it to WD to get authorisation before the work begins, on the other hand if your handy with the spanners and the part isn’t to expensive then it may be less hassle to get it sorted right and then you have piece of mind it won’t go again Clickadeeclick
Post #544218 Thu Dec 28 2017 10:55am
d-9
Mine had been glued back together when I bought the car, a week in there was a load bang and it blew a hole big enough to get my finger in. Given the pita removing injectors etc to get to the manifold, I would just replace it.
Post #544219 Thu Dec 28 2017 10:57am
LTB00768v2 a Pdf copy is in my gallery, not sure how to add it to post.
This post might help.
http://www.rrsport.co.uk/forum/topic46397.html
or
https://www.aulro.com/afvb/l319-discovery-...blems.html
Post #544223 Thu Dec 28 2017 11:24am
DSJ
thanks, read these two thoroughly last night.
don't know how many on here have got LR to repair free of costs, when they have just told me the opposite this morning???
Post #544224 Thu Dec 28 2017 11:31am
Jampot1979
United Kingdom 2008 Range Rover Sport TDV8 HST Java Black
I had the driver's side inlet manifold replaced on my TDV8 last month due to a hairline crack. Cost me approx £750 all in by my local specialist. It's abit of a pain to get at and remove but they did it all in approx 4 hours. I would rather replace than glue. I would worry about it failing.
Post #544225 Thu Dec 28 2017 11:38am
N60613
Bosnia Herzegovina
DSJ, can you post picture of the crack?
Post #544236 Thu Dec 28 2017 12:52pm
DSJ
here you go - from another thread.
Post #544237 Thu Dec 28 2017 1:02pm
DSJ
Post #544238 Thu Dec 28 2017 1:02pm
