![]() | Home > Technical > Intake Manifold Repair |
N60613 Member Since: 24 Jun 2016 Location: capljina Posts: 32 ![]() ![]() |
Rockyward Member Since: 17 Jun 2020 Location: Derby Posts: 3 ![]() ![]() ![]() |
Anyone tried to repair the crack using superglue and baking soda ?
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4430 ![]() ![]() ![]() |
Problem is, the manifolds are a weak design
Mine is only a small crack I think I'm going to try super glue and baking soda, I have 3 weeks to wait before the Dealer can look at it.
Stand Easy Member Since: 10 Aug 2016 Location: Manchester Posts: 126 ![]() ![]() ![]() |
Both mine cracked, warranty specifically said inlet manifolds weren't covered, however, given that my engine had been refurbed by the same warranty firm they agreed to pay half the costs. Had a quote of £750 for genuine parts all fitted, clearly a cheap quote |
Iomegas Member Since: 15 Nov 2020 Location: Newcastle Upon Tyne Posts: 213 ![]() ![]() ![]() |
Hi i had a interesting call with LR Customer service or non service to be honest.So there is a LR bulletin LTB00768v2 an official document that states under cause:Material Thickness and fillet radius of the valve cover not to specification.I asked as they state it’s not to specification so by that statement not fit for purpose they would be replacing any defective units covered by the vin numbers they listed free of charge?Guess what they said NO! as there had not been a recall.So they can release cars with parts that fail their own specifications and put them on vehicles with no recourse.
Apples24 Member Since: 04 Aug 2020 Location: Southampton Posts: 5 ![]() ![]() ![]() |
How did you get on with the glue repair? |
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 138 ![]() ![]() |
Drill a hole whose diameter is at least twice the width of the crack at both ends. Then use the superglue-baking soda method to seal up the crack. |
