Home > Faults & Fixes > Normal Suspension height fault codes
Highside
I have a suspension fault which I need some help with.
I've invested in a 'IIDTool BT' and have some fault codes which I'm hoping you can help me with........
First off, the compressor isn't operating, I've checked the relay and it's being powered and there is 12V across the contact also.
I've measured at the compressor connector and on start up the power is applied until the fault is detected.
I know it sounds obvious that it's the compressor that's failed but I replaced it in the last 2 years so just want to verify that there isn't some control logic preventing it from running.
If there is power to the relay as above does that negate the pressure switch, valves etc?
Thanks in advance for any help
Rob
Post #543783 Wed Dec 20 2017 4:22pm
Scrumpy
Hi Rob,
might not be much help but as you have the IID tool have you updated the compressor software?
It's easy to do and you never know, it could (if you're lucky) fix your faults.
Good luck 2016 RRS SVR Estoril Blue
Post #543785 Wed Dec 20 2017 4:44pm
Highside
Scrumpy, thanks for the heads up, reflash done, very simple as you say but ALAS, not the fix!
Appreciate you taking the time to post, thanks
Rob
Post #543790 Wed Dec 20 2017 5:30pm
Might be worth checking the compressor inlet pipework. If it's blocked/partially blocked then that will prevent the system from raising the vehicle.
From the book of lies:
Quote:
Compressor fault
Reservoir pipe air leak
Reservoir air leak
Gallery pipe air leak
Intake filter blocked/restricted
Intake pipe blocked/restricted
Air suspension intake silencer blocked/restricted
Corner valve stuck open
Pressure sensor fault
Edit: The inlet filter is behind the trim panel in the boot on the left hand side. The pressure sensor is in the valve block next to the compressor. 2012 SDV6 - it's missing a couple of cylinders
Post #543794 Wed Dec 20 2017 6:22pm
Highside
RRSTDV8, thanks for the response.
Compressor doesn't start, don't want to admit it but looking like I need my second one within 2 years.
Looking at the AMK Upgrade!
Big Cry Big Cry
Post #543796 Wed Dec 20 2017 8:51pm
GARYF123
Mine just had second AMK in 2 years! Had amber warning light so indy changed filter and discovered that one of the pipes from the compressor that goes inside the tailgate panel and sucks clean air in was missing, therefore sucking dirty air in and causing compressor to struggle! Best part of £700.00 later...
Post #543798 Wed Dec 20 2017 9:21pm
Highside, it would still be worth checking that the pipes are clear. No point killing another compressor. 2012 SDV6 - it's missing a couple of cylinders
Post #543799 Wed Dec 20 2017 9:56pm
