![]() | Home > Faults & Fixes > Normal Suspension height fault codes |
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 ![]() ![]() |
Hi Rob,
Highside Member Since: 03 Oct 2015 Location: Wirral Posts: 7 ![]() ![]() ![]() |
Scrumpy, thanks for the heads up, reflash done, very simple as you say but ALAS, not the fix!
Might be worth checking the compressor inlet pipework. If it's blocked/partially blocked then that will prevent the system from raising the vehicle.
Edit: The inlet filter is behind the trim panel in the boot on the left hand side. The pressure sensor is in the valve block next to the compressor. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
RRSTDV8, thanks for the response.
GARYF123 Member Since: 03 Jan 2015 Location: leeds Posts: 143 ![]() ![]() ![]() |
Mine just had second AMK in 2 years! Had amber warning light so indy changed filter and discovered that one of the pipes from the compressor that goes inside the tailgate panel and sucks clean air in was missing, therefore sucking dirty air in and causing compressor to struggle! Best part of £700.00 later... |
Highside, it would still be worth checking that the pipes are clear. No point killing another compressor. 2012 SDV6 - it's missing a couple of cylinders
