Home > Wheels & Tyres > The code reads 20 9.5 JJ ET 45 Alloy rims
harrij07
Switzerland 2012 Range Rover Sport 3.0 TDV6 HSE Galway Green
So I purchased some alloy rims, very nice Style 6 for my RRsport 2013
The do not fit on the hubs!!!!
I do not feel like the sharpest arrow in the quiver right now...
Any reason as why they do not fit?
Cheers and merry chrimbo MY 2012 SDV6
1996 300TDI Discovery - Expedition prepared and blooded
1952 Land Rover 80 inch
Post #542907 Fri Dec 08 2017 12:12pm
Eaters
If they go on but foul on something, it sounds like your offset may be wrong. On mine (admittedly an earlier model and V8 ) the offsett needed is ET53 and you seem to have 45
Are to stud holes in the right place? Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #542917 Fri Dec 08 2017 2:35pm
If they don't fit the stud pattern or locate on the hub spigot, then they are not genuine L/R rims as all sport rims are 5 x 120 pcd and I think the spigot bore is 72.9mm I could be wrong on that measurement, but all 05 - 17 sports are the same although they do have different offsets depending on diam. and width if I remember correctly. Even the old P38's and disco's were 5 x 120 except the original disco 1, although a different spigot bore diam.
Post #542953 Fri Dec 08 2017 7:33pm
harrij07
Thanks for the responses
The have a landcover style for sure. Not sure if they are genuine, but they must fit some car.
Time to flip them.
John MY 2012 SDV6
Post #542961 Fri Dec 08 2017 8:28pm
Eaters
If you have a look on the reverse of the wheel, you should see all the details you need including a LR mark (if genuine) Robin
Gone:
MGZTT 190 2.5
Post #542975 Fri Dec 08 2017 11:08pm
