Home > Wheels & Tyres > The code reads 20 9.5 JJ ET 45 Alloy rims |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1538 |
If they go on but foul on something, it sounds like your offset may be wrong. On mine (admittedly an earlier model and V8 ) the offsett needed is ET53 and you seem to have 45
Fri Dec 08 2017 2:35pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4969 |
If they don't fit the stud pattern or locate on the hub spigot, then they are not genuine L/R rims as all sport rims are 5 x 120 pcd and I think the spigot bore is 72.9mm I could be wrong on that measurement, but all 05 - 17 sports are the same although they do have different offsets depending on diam. and width if I remember correctly. Even the old P38's and disco's were 5 x 120 except the original disco 1, although a different spigot bore diam.
Fri Dec 08 2017 7:33pm |
harrij07 Member Since: 23 Mar 2016 Location: Tenniken Posts: 46 |
The have a landcover style for sure. Not sure if they are genuine, but they must fit some car.
Fri Dec 08 2017 8:28pm |
If you have a look on the reverse of the wheel, you should see all the details you need including a LR mark (if genuine) Robin
Fri Dec 08 2017 11:08pm |
