![]() | Home > Technical > Ace pipes leaking |
Wasn't there a thread on this recently?
reeces555 Member Since: 13 Apr 2017 Location: Worcestershire Posts: 8 ![]() ![]() |
Cheers mate! Called a garage and was quoted £1800 plus VAT as body needed taking off. 2nd garage said it didn't need taking off and was 5 hours work. |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4420 ![]() ![]() ![]() |
I have spent 5 hours trying to get the seized pipes out of the valve block before |
I'm just getting more releived at the fact it can be done with removing the body mate. |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9022 ![]() ![]() ![]() |
Taking the body off isn't a big issue. The vehicle is designed to have it done and doing it can make jobs easier and thus quicker. Also better access means a better job is more likely. Compared to the price of many LR parts these days, the cost of body on and off isn't that big. 2012 SDV6 - it's missing a couple of cylinders
You must be able to do it with your eyes shut now! |
Body off, engine out (2.7) and mostly stripped in 6 hours... |
