Home > Technical > Ace pipes leaking
reeces555
Ace pipes leaking
I have a 2007 range rover sport which needs the pipes replacing that run into the ace filter block. My question is can this be done without taking the body off? I've taken a picture which hopefully is clear.
Post #541944 Mon Nov 27 2017 1:00pm
Paddi
Wasn't there a thread on this recently?
Oh here you go:
http://www.rrsport.co.uk/forum/topic48470....=Ace+pipes
With all due credit to forum contributor stretch. 2008 MY Java Black TDV8 HSE
Post #541949 Mon Nov 27 2017 1:52pm
reeces555
Cheers mate! Called a garage and was quoted £1800 plus VAT as body needed taking off. 2nd garage said it didn't need taking off and was 5 hours work.
Post #541950 Mon Nov 27 2017 1:55pm
Disco_Mikey
I have spent 5 hours trying to get the seized pipes out of the valve block before Shocked
Generally, I allow 8 hours for front pipes, as a worst case Thumbs Up
Post #541953 Mon Nov 27 2017 2:45pm
reeces555
I'm just getting more releived at the fact it can be done with removing the body mate.
Post #541954 Mon Nov 27 2017 2:49pm
Taking the body off isn't a big issue. The vehicle is designed to have it done and doing it can make jobs easier and thus quicker. Also better access means a better job is more likely. Compared to the price of many LR parts these days, the cost of body on and off isn't that big. 2012 SDV6 - it's missing a couple of cylinders
Post #541988 Mon Nov 27 2017 7:13pm
Disco_Mikey
Censored Im fed up of body off jobs Rolling Eyes
8 of the Censored since September, another 2 imminently, and and a further 2 in Jan Big Cry
Anyway, I think book time is 5.5 hours to remove + refit the body. Allow an extra couple of hours to deal with the inevitable rusty/seized fixings. Not the end of the world Thumbs Up
Post #541993 Mon Nov 27 2017 7:24pm
You must be able to do it with your eyes shut now! Rolling with laughter 2012 SDV6 - it's missing a couple of cylinders
Post #542004 Mon Nov 27 2017 8:52pm
Disco_Mikey
Body off, engine out (2.7) and mostly stripped in 6 hours... Mr. Green
Post #542009 Mon Nov 27 2017 9:13pm
