Home > In Car Electronics > USB through AUX
Cymruambyth
Wales
USB through AUX
I bought a lead which I can put a memory stick into and then plug into the AUX socket. According to the description, music should play through this way, but it doesn`t. All I get is a low power message on the display! It does mention U disc...no idea what that is so I took a punt. Any ideas?
This is the lead http://www.ebay.co.uk/itm/3-5mm-Male-AUX-A...Swol5Ywkg2 Steve.
Post #538861 Sat Oct 21 2017 2:25pm
jimbg
Attention:
1. Only work when your car AUX have decode function
2. Only car AUX interface have the function of read U disk can use this kind of line
3. U disk had better not store too much, we suggest LESS THAN 8GB
4. Can NOT work as a charger
Fairly sure the Sport fails on 1 and 2!! 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #538862 Sat Oct 21 2017 2:30pm
Cymruambyth
Wales
Yeah saw that. Mp3 player works through it and it`s only around 2GB of music on the stick. It was the U disc I was wondering about?! Steve.
Post #538866 Sat Oct 21 2017 2:37pm
jimbg
Yes, but your MP3 player is outputting an analogue audio signal that it has generated from the digital file
This is I presume sending a digital stream that needs decoding into an audio signal. It has no inteeligence and is looking for your Sport to do that work.
Sport's are not known for their intelligence!! Rolling with laughter 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #538868 Sat Oct 21 2017 2:44pm
Cymruambyth
Wales
Haha...ah right ok. No worries, it was only a quid Thumbs Up Steve.
Post #538869 Sat Oct 21 2017 2:46pm
Socast
Try one of these instead: http://www.ebay.co.uk/itm/3-5mm-USB-Blueto...SwufpZwd8F
Post #538966 Mon Oct 23 2017 2:09pm
Cymruambyth
Wales
Cheers for that but I don`t have a USB in my car. Steve.
Post #538968 Mon Oct 23 2017 2:28pm
Socast
Sorry, normally those adapters have a battery in them and the usb is to charge the battery.
Try this one instead, I can't seem to find a link to the one I bought:
http://www.ebay.co.uk/itm/3-5mm-Wireless-B...100623.m-1
Post #538974 Mon Oct 23 2017 2:50pm
Cymruambyth
Wales
Ahhh, just thought, I still couldn`t use a memory stick with one of those. My mp3 player works through AUX but it`s just fiddly to use Rolling Eyes Steve.
Post #538975 Mon Oct 23 2017 2:55pm
Socast
That adapter would mean you could play music off your phone (which is what I do). I've fitted a USB port to my car, but it's only for charging, there's no connection between it and the head unit.
Post #538977 Mon Oct 23 2017 3:16pm
Cymruambyth
Wales
Thumbs Up Steve.
Post #538978 Mon Oct 23 2017 3:17pm
jimbg
https://www.lifewire.com/usb-to-aux-cable-in-car-audio-3986249 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #538985 Mon Oct 23 2017 3:52pm
Eaters
Steve
Your requirement was for a way to play a usb stick through your aux jack. If that’s what you still want then this won’t help you.
But if you want Bluetooth music from your phone and phone call functionality then have a look at this.
Kinovo BTC 450
I got one from Amazon (on the recommendation of someone on the forum) and it’s really good. Thumbs Up Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #539002 Mon Oct 23 2017 5:53pm
