![]() | Home > In Car Electronics > USB through AUX |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
I bought a lead which I can put a memory stick into and then plug into the AUX socket. According to the description, music should play through this way, but it doesn`t. All I get is a low power message on the display! It does mention U disc...no idea what that is so I took a punt. Any ideas?
Yeah saw that. Mp3 player works through it and it`s only around 2GB of music on the stick. It was the U disc I was wondering about?! Steve. |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1856 ![]() ![]() |
Yes, but your MP3 player is outputting an analogue audio signal that it has generated from the digital file
Haha...ah right ok. No worries, it was only a quid |
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
Try one of these instead: http://www.ebay.co.uk/itm/3-5mm-USB-Blueto...SwufpZwd8F |
Cheers for that but I don`t have a USB in my car. Steve. |
Sorry, normally those adapters have a battery in them and the usb is to charge the battery.
Ahhh, just thought, I still couldn`t use a memory stick with one of those. My mp3 player works through AUX but it`s just fiddly to use |
That adapter would mean you could play music off your phone (which is what I do). I've fitted a USB port to my car, but it's only for charging, there's no connection between it and the head unit. |
https://www.lifewire.com/usb-to-aux-cable-in-car-audio-3986249 2023 P440e SE Dynamic on order -cancelled
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
Steve
