Home > Wheels & Tyres > 275/45/20” GGAT3s
R44dgf
275/45/20” GGAT3s
Just fitted a set of these on my 2012RRSSDV6 any suggestions on tyre pressures normal loading most of the time thanks in advance
Post #537262 Wed Oct 04 2017 1:07pm
Normal book pressures, I would suggest. 2012 SDV6 - it's missing a couple of cylinders
Post #537293 Wed Oct 04 2017 4:14pm
R44dgf
Tyres
Thanks didn’t know if they was standard fitment
Post #537295 Wed Oct 04 2017 4:17pm
They're not standard size but if you start with LR's pressures you can easily adjust them slightly to counter any adverse wear or other issues. At least you know you're starting from a reasonable pressure. 2012 SDV6 - it's missing a couple of cylinders
Post #537306 Wed Oct 04 2017 5:03pm
geoffsnook
So do you need to tell the car it has a larger diameter wheel/tyre diameter Thumbs Up
Post #537354 Wed Oct 04 2017 8:24pm
Johnski
You can adjust using a Gap IID BT Tool, (ensure you do backup) but I found the difference so small not worth bothering with to be honest.
Generally......If you have a separate sat nav that shows MPH try it before changing from 275/40/20 Tyres, then again with new Tyres fitted and you can decide for yourself. John
Post #537360 Wed Oct 04 2017 9:21pm
geoffsnook
Thanks tried it today the speedo set 70 the cruise said 68 and sat nav said 72 so if you could let Mel ow where to find it on the iid I would be grateful Thumbs Up
Post #537363 Wed Oct 04 2017 9:32pm
The difference at 30mph would be about 1mph which would probably actually make the speedo more accurate, as John said not worth bothering with, even on mine with 275/45 x 21 the variation is minimal.
Post #537366 Wed Oct 04 2017 9:55pm
geoffsnook
Thanks C||ol but my speedo was not reading as quick as i was actually going saying 70 and sat nav saying 72 so i could be in danger of getting a ticket so if its possible i would like to see Thumbs Up
Post #537435 Thu Oct 05 2017 2:36pm
