![]() | Home > Wheels & Tyres > 275/45/20” GGAT3s |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9031 ![]() ![]() ![]() |
Normal book pressures, I would suggest. 2012 SDV6 - it's missing a couple of cylinders
R44dgf Member Since: 25 Jul 2017 Location: Much Hadham Sg10 6hg Posts: 55 ![]() ![]() |
Thanks didn’t know if they was standard fitment |
They're not standard size but if you start with LR's pressures you can easily adjust them slightly to counter any adverse wear or other issues. At least you know you're starting from a reasonable pressure. 2012 SDV6 - it's missing a couple of cylinders
So do you need to tell the car it has a larger diameter wheel/tyre diameter |
You can adjust using a Gap IID BT Tool, (ensure you do backup) but I found the difference so small not worth bothering with to be honest.
Thanks tried it today the speedo set 70 the cruise said 68 and sat nav said 72 so if you could let Mel ow where to find it on the iid I would be grateful |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5046 ![]() ![]() ![]() |
The difference at 30mph would be about 1mph which would probably actually make the speedo more accurate, as John said not worth bothering with, even on mine with 275/45 x 21 the variation is minimal.
Thanks C||ol but my speedo was not reading as quick as i was actually going saying 70 and sat nav saying 72 so i could be in danger of getting a ticket so if its possible i would like to see |
