![]() | Home > Technical > Fault Codes P006A-00 & P1247-00, Restricted Performance |
You need to get the stored codes removed and then read with correct equipment, LR garage or GAP IID Tool BT or similar.
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 ![]() ![]() ![]() |
i had the same problems, till it got worse and the DPF anex catalyst converter melted down.
johnhorgan Member Since: 25 Sep 2019 Location: Nelson Posts: 2 ![]() ![]() ![]() |
Did you ever figure out the problem? I have the same. |
