Home > Technical > Fault Codes P006A-00 & P1247-00, Restricted Performance
Oldandconfused
Disco_Mikey wrote:
3.0 cannot blank the EGR, as they are needed as part of the DPF regeneration...
Personally, never seen a faulty 3.0 EGR valve yet...
Thanks for that Thumbs Up
I managed to get one without DPF anyway.
Post #536317 Sun Sep 24 2017 1:33pm
Johnski
You need to get the stored codes removed and then read with correct equipment, LR garage or GAP IID Tool BT or similar.
I'm shocked that a garage would return a car with same/similar faults and indications as when it went in. Don't they test drive afterwards? Whistle John
Post #536346 Mon Sep 25 2017 12:54am
Hog
Netherlands 2012 Range Rover Sport SDV6 HSE Lux Buckingham Blue
i had the same problems, till it got worse and the DPF anex catalyst converter melted down.
I would not exclude a blocked DPF indeed RRS 3.0 SDV6 HSE Lux
RRS 3.0 TDV6 gone
LR 3 HSE V8 gone
DiscoveryII V8 Gone
Discovery 1 V8 Gone
Mustang Shelby
Alfa Guilia (classic)
Post #536383 Mon Sep 25 2017 3:48pm
johnhorgan
New Zealand 2007 Range Rover Sport TDV6 HSE Siberian Silver
Did you ever figure out the problem? I have the same.
Post #634932 Tue Aug 08 2023 9:06pm
