Home > General (L494) > Engine failure
Page 2 of 5 <12345>
SVR575
Even if they did not use the right oil it was serviced by LR so its there problem.udash has done every thing right even checking oil daily which is a pain in the arse with that electric sensor. SVR 2018 in Santorini Black.
Post #533161 Fri Aug 18 2017 12:20pm
wilf
Udash - be sure to keep us up to date with how this unfolds please? MY2016 HSE D SDV6 - gone due to fuel dilution problems.
By the age of 50 you have the face you deserve - George Orwell.
Post #533163 Fri Aug 18 2017 12:46pm
Hog
Netherlands 2012 Range Rover Sport SDV6 HSE Lux Buckingham Blue
True TDV8HST, however during my expierence JLR took an oil monster of my car, before they authorized the dealer to swap the engine.
The dealership here in Lagos uses 5W40 917A Castrol oil and sometimes even 20W50 GTX! I always insisted on the right specs 5W30.
You do not want to become a victim of kicking the ball between dealership and JLR. RRS 3.0 SDV6 HSE Lux
RRS 3.0 TDV6 gone
LR 3 HSE V8 gone
DiscoveryII V8 Gone
Discovery 1 V8 Gone
Mustang Shelby
Alfa Guilia (classic)
Post #533165 Fri Aug 18 2017 1:07pm
udash
2013 Range Rover Sport SDV6 Autobiography Firenze Red
Certainly will keep updated, got a call today from the European operations team, they say that the transporter has provisionally set the car to be with my local dealer by 31st of this month, but perhaps few days earlier.
Also called LRCR and opened a case and requested a loan car with similar spec.
Post #533178 Fri Aug 18 2017 6:57pm
udash
Just an update, mine has landed in the UK, so should arrive at the local dealer next week to find out the damage.
I got a RRS HSE with 50 miles on the clock as my loan car, its MY17 so certainly the dash and ICE is lot faster then MY16, but noticed that the engine noise is lot more noticeable from inside the car, just wondering if the AB spec actually has more sound insulation as part of the AB trim.
If so another good reason for choosing AB, for those who trying to decide between HSE+ options vs AB when ordering.
Post #533854 Sat Aug 26 2017 10:15am
Gosser
My year old 18000 mile RRS engine gave up whilst on holiday in Cornwall. Crankshaft bearing went and the whole bottom end seized solid! Land Rover were not keen to tell me what had gone wrong, but I persisted until I got an answer. Bill was over £17,000 and the car will be gone before the end of its warranty!!!
Post #533950 Mon Aug 28 2017 10:37am
udash
what was the LR answer, while mine has not seized, German technician said its most probably Crankshaft or its bearings that has failed.
Post #533974 Mon Aug 28 2017 5:52pm
udash, it will interesting to get confirmation whether it's the cranshaft, because everyone at LR claims that this problem has been rectified from My12 onwards when they took over the production from Ford.
Rolling Eyes --
Post #534104 Wed Aug 30 2017 1:57pm
udash
An Update.
Car arrived yesterday (without any bodywork damage as far as I can see) and dealer had a look and the crank shaft has broken in to two!
They have already started the process of ordering a new engine with all the components due to metal particle contamination.
I had a chat with the lead technician who was genuinely sorry for what happened, and said that it even worries him as he has the same engine in his D4.
He said that old 2.7L engine had this issue but it’s not common with the 3L, so could be due to manufacturing fault rather than inherent issue. Dealer said that they would work with LR to restore my faith in LR, so let’s see how that pans out.
Post #534216 Thu Aug 31 2017 7:38pm
wilf
Well, failures do happen.
The early 3.0s had major crank failure problems, but it showed up in places like the US, South Africa and Australia, not sure why. We didn't see it so much here. But when one of these engines lets go, it usually is the bottom end failing catastrophically, and LR isn't letting on why. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Post #534220 Thu Aug 31 2017 7:43pm
Revoke
Get some of the engine oil if you can and have it checked for diesel dilution and other evidence of poor lubrication.
It will cost £30 here. http://www.millersoils.co.uk/services/oil-analysis
Post #534443 Sun Sep 03 2017 10:10am
Johnski
Anything to do with this, as when not done reports of engine failure?
https://www.discosportforums.co.uk/downloa...a20f1ee072 John
Post #534455 Sun Sep 03 2017 1:19pm
Revoke
The SCN is quite blunt, "Continued vehicle operation with high oil dilution WILL result in engine failure." And this is an "engine failure" if ever there was one. Obviously no-one can say that it was the cause in this unfortunate case and probably only the company will ever get to know precisely why this particular crankshaft failed. But if the car is in the affected group (which it seems to be) surely poor lubrication needs to be "eliminated from enquires", as George Gently might put it.
Post #534469 Sun Sep 03 2017 4:14pm
Black Bess
chucking in my twopenneth;
In my experience (30 years in the motor repair trade), oil dilution will result in damage to bearing surfaces. In the case of the bottom end, the big-ends would fail first, before the main bearings. Damage would also occur to cylinder bores and camshaft lobes.
A broken crank starts out as a cracked crank which gets much worse! Lubrication is not the cause. Metallurgy, such as incorrect heat treatment, might be.
Post #534501 Mon Sep 04 2017 10:09am
drdelrrs
Diluted lubrication is bad news all round. Cranks will fracture (particularly at rear main) if piston(s) pick-up and partially seize while other cylinders are still producing power.
The older Jaguar 6 cylinder mills could do this and the end float would allow the thrust bearings to drop out of position.
Post #534662 Wed Sep 06 2017 11:08am
Page 2 of 5 <12345>
