Home > Maintenance & Modifications > MY 2013 RRS Heated Steering Wheel Upgrade |
Lonescout Member Since: 30 Aug 2016 Location: UK Posts: 35 |
Duplicate post Ooops! |
Tue Jun 20 2017 6:24pm |
Evo5man Member Since: 04 Jun 2017 Location: Skegness, Lincolnshire Posts: 222 |
I hope that my upgrade goes as simply as yours!
Tue Jun 20 2017 6:30pm |
There's plenty of info on our sister forum, with pictures too. It's easy enough to check your clock spring, you just need to remove your steering wheel. A 25 minute job - 20 of those waiting after disconnecting the battery (airbag safety)! |
Tue Jun 20 2017 6:36pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4971 |
Exactly same principal to remove 2013 wheel.
Tue Jun 20 2017 9:29pm |
Thanks for the Video link Col
Wed Jun 21 2017 8:58am |
There are 2 types of ECU that come in the heated wheel. The later type will not work, i had a 2014 Discovery 4 heated wheel and Dan at Duckworths sent me every switch pack going and i still couldn't get it to work
Wed Jun 21 2017 9:36am |
Hi,
Wed Jun 21 2017 9:47am |
Thanks Buckster
Wed Jun 21 2017 9:49am |
Thanks Col I think that I will either buy new or wait for a mint used 2013 RRS heated wheel to come up on fleabay to ensure compatibility, don't want to end up with a garage full of steering wheels, switch packs and clocksprings that won't fit or work I have plenty of time before the winter arrives. At the moment we could do with a chilled steering wheel option here, 31 Deg C expected today!!! Cheers Steve |
Wed Jun 21 2017 9:56am |
How about fitting one of these wheels.
Wed Jun 21 2017 9:58am |
Now that looks like the Bee's Knees
Wed Jun 21 2017 10:35am |
They work out quite expensive really but are excellent quality and although they may not look it are a very comfortable grip, and as it is a original spec. wheel switches and paddles fit perfectly.
Wed Jun 21 2017 10:59am |
Disco 4 Lux wheel and paddles are the same, but need to be from an earlier car to have the older style ECU. I couldn't get the new style ECU to work using Dans assortment of switch packs.
Wed Jun 21 2017 11:43am |
Gerd1986 Member Since: 07 Oct 2015 Location: London Posts: 303 |
@col - Does the piano black part of that steering wheel heat up also or is it just the leather part? |
Wed Jun 21 2017 12:22pm |
