![]() | Home > Maintenance & Modifications > MY 2013 RRS Heated Steering Wheel Upgrade |
Evo5man Member Since: 04 Jun 2017 Location: Skegness, Lincolnshire Posts: 222 ![]() ![]() ![]() |
Hi there,
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5041 ![]() ![]() ![]() |
You will also need the tool to release the Airbag about a tenner of fleabay, if you are lucky on a 2013 car it should already have the correct clockspring, but you would need to remove wheel first to make sure. I also have all the part numbers some where, will dig them out for you. Pity as I have a virtually brand new steering wheel here, unfortunately though I'm the other side of the world. |
Hi Tim, Thanks for the reply. I will check out with my local LR Dealer if I need to have this option enabled. |
Thanks Col, I have sent you a PM about your wheel. Cheers Steve |
Buckster Member Since: 05 Mar 2015 Location: Hampshire Posts: 1656 ![]() ![]() ![]() |
I did this upgrade and my advice to you would be use Dan at Duckworth parts to supply you with the correct bits for the job. Quote the forum for some discount
Hi Buckster,
I dont have the part numbers to hand as im away at the minute but Col will probably have them long before i do!!
Thanks Buckster |
Steve,
Thanks Col, you have been an absolute star |
Thanks Col, hope all is well in NZ |
All good down here Buddy, best move I ever made (no pun intended) haven't missed the U.K. one little bit, especially with all the s**t you guys have going on over there at the moment. |
Lonescout Member Since: 30 Aug 2016 Location: UK Posts: 35 ![]() ![]() |
Did this mod on our 2006 L320. Easy mod, took about 1.5 hours including swapping new circuit boards (can compatible from BBS) and soldering the radio receiver into the gearbox wiring for the tiptronic gear change.
Thanks Lonescout,
