![]() | Home > Maintenance & Modifications > MY 2013 RRS Heated Steering Wheel Upgrade |
Lonescout Member Since: 30 Aug 2016 Location: UK Posts: 35 ![]() ![]() |
Duplicate post Ooops! |
Evo5man Member Since: 04 Jun 2017 Location: Skegness, Lincolnshire Posts: 222 ![]() ![]() ![]() |
I hope that my upgrade goes as simply as yours!
There's plenty of info on our sister forum, with pictures too. It's easy enough to check your clock spring, you just need to remove your steering wheel. A 25 minute job - 20 of those waiting after disconnecting the battery (airbag safety)! |
Exactly same principal to remove 2013 wheel.
Thanks for the Video link Col |
There are 2 types of ECU that come in the heated wheel. The later type will not work, i had a 2014 Discovery 4 heated wheel and Dan at Duckworths sent me every switch pack going and i still couldn't get it to work |
Thanks Buckster |
Thanks Col ![]() ![]() Cheers Steve |
How about fitting one of these wheels.
Now that looks like the Bee's Knees |
They work out quite expensive really but are excellent quality and although they may not look it are a very comfortable grip, and as it is a original spec. wheel switches and paddles fit perfectly.
Disco 4 Lux wheel and paddles are the same, but need to be from an earlier car to have the older style ECU. I couldn't get the new style ECU to work using Dans assortment of switch packs.
Gerd1986 Member Since: 07 Oct 2015 Location: London Posts: 303 ![]() ![]() ![]() |
@col - Does the piano black part of that steering wheel heat up also or is it just the leather part? |
