Home > Maintenance & Modifications > 2006 Inconsistent Cruise Control
Graz
Every so often the cruise control won't work and there seems to be no pattern to this but when you. Is this a known common fault?
Post #526223 Tue May 16 2017 8:06pm
Diesel or petrol
Fill out your profile please
Post #526224 Tue May 16 2017 8:11pm
Graz
Hi Andy, it's a 2.7 diesel
Post #526226 Tue May 16 2017 9:17pm
Pufftmw
Doesn't work under 20mph, which is a pain for the Rotherhithe Tunnel and I would not say it was particularly good anyway. Sometimes it stays at the posted speed, other times it drops off, then works out its slow and speeds up again and then proceeds to exceed the posted speed Rolling Eyes Its not capable of working out when it is or isn't under load I think.
OTOH I had a manual diesel 2.4 Volvo XC70 and you could post a speed and within 1mph either way, it would stick to it - M11 between J8&9 was a good test with all those long hills.
Post #526240 Wed May 17 2017 8:23am
Bill Portland
have you got adaptive cruise control? Merc C220 estate Sport AMG
Merc C220 estate Sport AMG 125 year edition
Alfa GT
Rover 76 V6
Post #526242 Wed May 17 2017 8:33am
Tim in Scotland
No adaptive cruise was available for the 2.7, only the 4.4V8, TDv8 and 4.2/5.0 S/C L320 got it 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #526248 Wed May 17 2017 8:58am
Graz
I've been tracking when it does and doesn't work and it appears to be when it has or is raining. Are any of the sensors under the bonnet or wheel arches?
Post #526280 Wed May 17 2017 8:58pm
TomTerrain
United Kingdom 2006 Range Rover Sport Supercharged HST Java Black
I have the same issue, sometimes it doesn't work, sometimes it does. I believe there's a common problem with a loom in the steering wheel! 2006 Java Black HST Supercharged
Post #526298 Thu May 18 2017 6:19am
M3DPO
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Baltic Blue
Correct Thumbs Up check for broken wires or loose connection and the clock spring.
Post #526310 Thu May 18 2017 8:58am
geoffsnook
Get a new steering wheel loom for inside the wheel.There not dear and it will more often than not sort it and very easy to do Thumbs Up
Post #526322 Thu May 18 2017 4:15pm
