Home > Maintenance & Modifications > 2006 Inconsistent Cruise Control |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4985 |
Diesel or petrol
Tue May 16 2017 8:11pm |
Graz Member Since: 22 Apr 2013 Location: Essex Posts: 104 |
Hi Andy, it's a 2.7 diesel |
Tue May 16 2017 9:17pm |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 |
Doesn't work under 20mph, which is a pain for the Rotherhithe Tunnel and I would not say it was particularly good anyway. Sometimes it stays at the posted speed, other times it drops off, then works out its slow and speeds up again and then proceeds to exceed the posted speed Its not capable of working out when it is or isn't under load I think.
Wed May 17 2017 8:23am |
Bill Portland Member Since: 01 Feb 2017 Location: Dorsetshire Posts: 387 |
have you got adaptive cruise control? Merc C220 estate Sport AMG
Wed May 17 2017 8:33am |
No adaptive cruise was available for the 2.7, only the 4.4V8, TDv8 and 4.2/5.0 S/C L320 got it 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Wed May 17 2017 8:58am |
I've been tracking when it does and doesn't work and it appears to be when it has or is raining. Are any of the sensors under the bonnet or wheel arches? |
Wed May 17 2017 8:58pm |
TomTerrain Member Since: 07 Sep 2015 Location: Wirral Posts: 93 |
I have the same issue, sometimes it doesn't work, sometimes it does. I believe there's a common problem with a loom in the steering wheel! 2006 Java Black HST Supercharged |
Thu May 18 2017 6:19am |
M3DPO Member Since: 30 Apr 2013 Location: Notts Posts: 36 |
Correct check for broken wires or loose connection and the clock spring. |
Thu May 18 2017 8:58am |
Get a new steering wheel loom for inside the wheel.There not dear and it will more often than not sort it and very easy to do |
Thu May 18 2017 4:15pm |
