![]() | Home > Technical > Disabling Active anti rollbar on TDV8 |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9039 ![]() ![]() ![]() |
Interesting. I always thought the D2 was rear only. Learn something every day |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4425 ![]() ![]() ![]() |
D2 had rear air only. Possibly that |
MakAtak67 Member Since: 27 Dec 2021 Location: Glasgow Posts: 4 ![]() ![]() ![]() |
Did just use the stock non-ace belt, or did you have to replace the tensioner too? I am thinking about a temp repair whilst I sort out a new pump. |
I have a 2006 RRS 2.7TDV6 and the bearing on the ACE pump has collapsed. New pump is over a grand. I have looked at the shorter belt, but does that also need a new pulley or do you just reroute and skip the ACE pump? Any help appreciated. |
To maybe answer my own question, I bought a non-ace belt (8PK2012) and tried to fit it by bypassing ace pump, but it's way too short.
You need a new alternator, mounting bracket, tensioner and belt to fit to the 2.7 |
Or, I've a new OEM pump on the shelf |
highladlandyman Member Since: 28 Nov 2018 Location: INVERNESS Posts: 3 ![]() ![]() ![]() |
Hi did you ever get a solution as to how to put light out on dash for the ace , I have just fitted the shorter belt pk6 1045 to get alt going and am planning to remove ace bars and fit std ones but am trying to get light reset have both nanocom and older hawkeye |
