Home > Technical > Disabling Active anti rollbar on TDV8
Camelrock
The D2 ACE operates on both front and rea axles, both rams are on the o/s the front one can be seen in the front wheel arch. 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #525808 Wed May 10 2017 3:30pm
Interesting. I always thought the D2 was rear only. Learn something every day Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #525848 Wed May 10 2017 10:30pm
Disco_Mikey
D2 had rear air only. Possibly that Thumbs Up
Post #525849 Thu May 11 2017 4:33am
MakAtak67
United Kingdom 2006 Range Rover Sport TDV6 HSE Santorini Black
Disco_Mikey wrote:
I'll be attempting this with my TDV8 Disco 3 Thumbs Up
Did just use the stock non-ace belt, or did you have to replace the tensioner too? I am thinking about a temp repair whilst I sort out a new pump.
Post #620295 Mon Dec 27 2021 1:31pm
MakAtak67
Lsv wrote:
Hello,
I managed to reroute the serpentine belt, without the ACE pump inline.
It merely uses a shorter belt. That was the easy part.
I'm curious about the software solution to shut off the ACE system. My local Landrover specialist said it wasn't possible?
What system can be used to deselect the ACE option? Does anyone perhaps have a screenshot? (ROVACOM/TESTBOOK or equivalent).
I got a used front sway bar and measured it and seems to fit without any problems, just a little of work. The rear bar seems to be a bit more work, as you need to lift the body slightly. The official way would be body off, but it should be possible to loosen the body bolts and gently lift the rear of the body. By this means there should be enough clearance to get the bar out.
This will also enable me to remove the dead weight counter weight parts on the back of the car.
Still thinking of pursuing it further from there... I have a Bowler EXR-S Rollcage lying around Smile
I have a 2006 RRS 2.7TDV6 and the bearing on the ACE pump has collapsed.
New pump is over a grand.
I have looked at the shorter belt, but does that also need a new pulley or do you just reroute and skip the ACE pump?
Any help appreciated.
Post #620296 Mon Dec 27 2021 1:47pm
MakAtak67
To maybe answer my own question, I bought a non-ace belt (8PK2012) and tried to fit it by bypassing ace pump, but it's way too short.
What am I missing?
Post #620299 Mon Dec 27 2021 2:35pm
Disco_Mikey
You need a new alternator, mounting bracket, tensioner and belt to fit to the 2.7 Thumbs Up
Post #620300 Mon Dec 27 2021 3:10pm
Disco_Mikey
Or, I've a new OEM pump on the shelf Thumbs Up
Post #620301 Mon Dec 27 2021 3:11pm
highladlandyman
United Kingdom 2008 Range Rover Sport TDV8 HSE Siberian Silver
Hi did you ever get a solution as to how to put light out on dash for the ace , I have just fitted the shorter belt pk6 1045 to get alt going and am planning to remove ace bars and fit std ones but am trying to get light reset have both nanocom and older hawkeye
Post #630360 Sat Jan 28 2023 1:57pm
