Home > Faults & Fixes > Blutooth
bicyclerepairman
United Kingdom 2007 Range Rover Sport TDV8 HSE Bonatti Grey
Blutooth
I have hunted the forum for answer to my bluetooth issue to no avail,
The symptom i get is as follows:
Bluetooth auto connects to car when I start the car.
I can start a phone call but after a while (sometimes minutes, sometimes seconds (10-15) there is a loud high pitched beep and the connection drops. The call is still there on the phone but not available in the car.
It is not the phone as it works perfectly in the 123d.
any ideas?
Post #524401 Mon Apr 24 2017 9:12pm
Socast
Try deleting the pairing on the phone and rebind them.
Post #524422 Tue Apr 25 2017 7:44am
bicyclerepairman
Ok thank you i'll try that and let you know
Post #524487 Tue Apr 25 2017 8:03pm
bicyclerepairman
I deleted the RR from the phone and reconnected a few days later. sadly the fault persists.
Any more ideas.
Post #525533 Sun May 07 2017 8:26pm
Eaters
As part of a process of elimination, can you try another phone to see if it happens Question Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #525541 Sun May 07 2017 10:43pm
bicyclerepairman
mmmmm
Ive tried a new samsung and it worked absolutely fine.
now very confused
any ideas
Post #527159 Tue May 30 2017 9:19pm
Eaters
So following my elimination process can we deduce:
- that the RRS side if things is fine as it works with the Samsung,
- and the phone with the issue still has the call, so it's not the mobile network side of things
Therefore it is the Bluetooth connection made by the suspect phone to the RRS. Not sure if that helps as you were probably there ahead of me. And I've no idea what you could try next. Something in the phone settings? Do you use the phone's Bluetooth on anything else e.g. Wireless speakers or something and if so does it work ok with them? (Not sure what 123D is I'm afraid)
What phone is it? Robin
Gone:
MGZTT 190 2.5
Post #527171 Tue May 30 2017 10:55pm
Tim in Scotland
You have a 2007 TDv8 listed as your car, can you say if it is the 2007 or 2007.5MY as there was a change in September 2007 when the cradle system under the centre cubby box lid was replaced by a fully B/T system - the only other change that you can tell if the car is 2007 or 2007.5 is that for 2007.5 electric steering column adjustment was also added to the spec then. It may be that if your car is the 2007MY with the Nokia cradle you may need a software upgrade as I doubt that there are any of the cradle attachments floating around these days for any of the modern smartphones. IIRC this is one of member Bodsy's specialities. Other option is to look for a Nokia 3110 handset............ 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #527190 Wed May 31 2017 8:08am
bicyclerepairman
Hi It is the 2007 not the 2007.5, although have had the bluetooth working for well over a year with no problems.
The 123d is a 1 series BMW. it is very odd as it works perfectly in that.
Phone also works briliantly on bluetooth speaker.
very confused
Post #527671 Mon Jun 05 2017 6:11pm
bicyclerepairman
forgot to mention that Bodsy has laid hands on the car in the past 18 months ago and got the phone working off bluetooth.
I have tried to contact Bodsy but have failed to track him down.
Post #527672 Mon Jun 05 2017 6:14pm
Eaters
A concurrent post on here would indicate that Bodsy is in high demand at present having been away on a break.
It sounds that he would be your best bet as he has been involved with your RRS before but you may have to be patient. Robin
Gone:
MGZTT 190 2.5
Post #527683 Mon Jun 05 2017 10:14pm
