Home > General > Which fuel do you use |
There are only a given number of refineries in the UK, ALL fuel suppliers get from the refinery nearest to them and the base fuel is all the same grade. Then suppliers allegedly add their own super potions - but all must meet the government minimum which is also what manufacturers build to.
Tue Apr 18 2017 9:18pm |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1538 |
This might help
Andrew Member Since: 16 Jun 2005 Location: Cheltenham Posts: 248 |
I have run standard octane fuel from either shell, bp or texaco for the life of my car, and it gets a good airing regularly, just to see, a couple of fills ago I let the tank run very low, filled with V power, run the tank very low again and filled with v power a second fill..
Tue Apr 18 2017 9:35pm |
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 311 |
In the sport I run diesel, haven't noticed any difference between the expensive vpower diesel and the cheap stuff from Sainsbury's, so it gets whatever is cheapest.
Tue Apr 18 2017 10:06pm |
sestorious Member Since: 12 Apr 2013 Location: doncaster Posts: 91 |
Cheers guys ! Like I say, I've never really been bothered ! I've just chose to always use vpower? Got nothing to do with going faster, just believed it would be better for my engine ! Was never keen to use supermarket fuel due to the horror story's I've heard ? |
Wed Apr 19 2017 5:46am |
The advantage of vpower petrol (and other varients of 'super'/'high test') is they have higher octane than regular (98/99/102 vs 95) this means you can run more ignition advance without detonation ('pinking'), more advance means better fuel economy and more power, within limits. Modern ignition systems detect detonation and retard the timing to prevent it, but as a side effect you can loose a lot of power if you run on regular fuel.
Wed Apr 19 2017 9:41am |
