Home > Maintenance & Modifications > Question about rear caliper pins |
CANROVER Member Since: 03 Oct 2015 Location: Ottawa Posts: 255 |
Hello everyone,
Sun Apr 09 2017 7:58am |
Gentlemen,
Tue Apr 11 2017 1:03pm |
Thanks Tom, that would be great!!!! |
Wed Apr 12 2017 1:42pm |
TomTerrain Member Since: 07 Sep 2015 Location: Wirral Posts: 93 |
Just had a quick trawl on some parts websites, I think the two pins should be the same! 2006 Java Black HST Supercharged |
Wed Apr 12 2017 1:51pm |
Not sure about that... It could be that this requirement is exclusive to the 2010+ Range Rover Sport Supercharged models.
Wed Apr 12 2017 8:03pm |
Hmmm, I did look at the 2010+ ones...
Wed Apr 12 2017 8:07pm |
It's weird because on the rear left side the pins were the same while the right side has the one pin with the sleeve. I'm thinking it *must* be like this because of the OEM package sold by Land Rover. |
Thu Apr 13 2017 12:42am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4969 |
Had a read of the Workshop Manual. and it does specifically say make a note of the guide pin orientation prior to removal, and to make sure the are re-fitted in the correct orientation. Which is great except it doesn't actually show a illustration or description of the pin's if they are different and which way round they go.
Thu Apr 13 2017 4:39am |
You're right, not much help but it was a good laugh.
Thu Apr 13 2017 6:44pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
Have a look here
Wed Apr 17 2019 10:40am |
OK so for future reference I nabbed the pic and confirmed. The Slider pin with the black end on it goes on the bottom.
Wed Apr 17 2019 11:04am |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849 |
I decided to paint my caliper and carrier yesterday. The top pin was the bushed one and after remembering this thread I checked and I thought it must have previously assembled incorrectly. So I set to assembling with the bushed pin at the bottom, and it jammed up. I managed to get it out in the vice and fit back in the original position and it fits perfectly. I’m thinking the left and right carriers are the same for both sides so the bushed pin is on the bottom when fitted to the left and top when on the right. 2019 5.0 SC SVA (Current)
Sat May 18 2019 11:43am |
That illustration and procedure is for a vehicle with standard Front Brakes, as I said previous the Workshop Manual for the Rears does specifically say make a note of the guide pin orientation prior to removal, and to make sure the are re-fitted in the correct orientation. Which is great except it doesn't actually show a illustration or description of the different pin's and which is the lower pin and which is the upper pin. Cheers Col Last edited by Col on Sat May 18 2019 12:37pm. Edited 1 time in total |
Sat May 18 2019 12:30pm |
Agh, got it. Good job I didn’t force it then lol. 2019 5.0 SC SVA (Current)
Sat May 18 2019 12:34pm |
