![]() | Home > Technical > Broke alternator carrier |
m3nutter Member Since: 08 Jul 2016 Location: Fairoak, Eastleigh Posts: 145 ![]() ![]() ![]() |
Started to take appart tonight to fit new alternator and .... |
Ouch, that doesn't look good.
It's been crap for the last two weeks or so! |
Is it just our login's |
It looks like three long bolts through into this bracket and pull the suspension pump away to get to the two angled bottom alternator bolts. I'm hoping enough flex in the hoses .. My concern is this bracket? Can't find one anywhere . It looks like the ace bracket is different to carry the pump ![]() |
I'm wondering if I can mount the top idler somewhere else , it doesn't seem to do a lot to me, just puts a bit more angle on the belt |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4457 ![]() ![]() ![]() |
I too have wondered why they felt the need for that pulley |
Me to, I may try and make a peice of steel angle to fit round what's left with a nut welded to hold the idler, or may just try it without? |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1194 ![]() ![]() ![]() |
maybe the workshop manual will help? see below --
Could be the engineers measured the belt requirements incorrectly ![]() ![]() Gone - A couple of RRS, A couple of Disco's. However thinking of another Sport. |
it wouldn't make any difference to the length - negligible, but you may be right in the sense of the distance between the water pump and the alternator. |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5039 ![]() ![]() ![]() |
Do ACE and non ACE cars have the same belt length ? |
No mate . The active one has a pump under alternator hence longer belt |
