![]() | Home > Technical > air suspension pressure ???? |
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
Not sure what pressure you're meant to get but the vehicle should raise and lower smoothly, if it's notchy when it lifts then your compressor's more than likely on the way out.
monkswood Member Since: 24 Aug 2016 Location: newcastle Posts: 14 ![]() ![]() ![]() |
The fault is suspension fault normal Height mode, I need to check the whole system including the reservoir for leaks also the intake filter for blockages etc. I have since found out the pressure should be about 16 bar and I'm getting about 14 bar so it could be the compressor requires an overhaul or one of the above
It should raise to 1779kpa
Thanks for the info. Compressor is booked in for a removal and refurb. Lower collapsible steering rod getting done at same time, hopefully that's it sorted for a couple of months LOL |
