Home > Technical > air suspension pressure ????
monkswood
United Kingdom 2007 Range Rover Sport TDV6 S Java Black
hi,
can anyone advise with what the air suspension pressure should be on an 07 RRS, I am currently getting 1500-1600 Kpa, but get a suspension fault, I'm trying to establish if it is a worn compressor or a pressure sensor problem
many thanks
Post #516381 Tue Jan 31 2017 3:07pm
Socast
Not sure what pressure you're meant to get but the vehicle should raise and lower smoothly, if it's notchy when it lifts then your compressor's more than likely on the way out.
Whats the error you're recieving ?
Post #516433 Wed Feb 01 2017 11:45am
monkswood
The fault is suspension fault normal Height mode, I need to check the whole system including the reservoir for leaks also the intake filter for blockages etc. I have since found out the pressure should be about 16 bar and I'm getting about 14 bar so it could be the compressor requires an overhaul or one of the above
Thanks
Post #516439 Wed Feb 01 2017 12:12pm
Bodsy
Site Sponsor
It should raise to 1779kpa
It's error because it's not getting up to pressure.
Either compressor if fubared or you have a leak. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #516489 Wed Feb 01 2017 9:38pm
monkswood
Thanks for the info. Compressor is booked in for a removal and refurb. Lower collapsible steering rod getting done at same time, hopefully that's it sorted for a couple of months LOL
Post #516502 Wed Feb 01 2017 10:56pm
