![]() | Home > Faults & Fixes > AFS Adaptive Front Lighting System warning light |
eugeneville Member Since: 16 Apr 2015 Location: Fleet Hampshire Posts: 33 ![]() ![]() |
Has anyone experienced anything similar to above? 2010 Supercharged |
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
It might be worth re-seating the connection to each of the headlights, disconnect give the plug a liberal squirt of electrical contact cleaner (Halfrauds sell it), give it a couple of mins to work it's magic, shake off any excess and reconnect.
Many thanks!
Two tabs either de of the headlights lift up and the unit will come forwards and lift out. There is a single plug that connects to the back of the unit with maybe 15 or 20 pins. Theres a little locking collar you need to squeeze to remove the plug. |
woodsie Member Since: 22 Nov 2015 Location: Milton Keynes Posts: 67 ![]() ![]() ![]() |
My indie told me not to use the lights switch in 'Auto' as they had seen a few burn out/short.
I'd find a new indie... |
