Home > Maintenance & Modifications > 2010 rrs 3.0 fan housing
merlin1
2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Doing a timing belt on my rrs , the early 2.7 u could remove the top of the fan housing the 3.0 looks like u have to remove the whole fan shroud , has anyone done there's , or is there enough room leaving the housing in place cheers in advance .
Post #515515 Sun Jan 22 2017 11:39pm
Socast
Not to be a Censored , but if you can't get the fan shroud off do you really think it's a good idea to attempt the cam belt ? Shocked
Post #515547 Mon Jan 23 2017 2:42pm
merlin1
Thankyou for your useless comment , I can get the fan housing off , but if I don't need to it will save a lot of time . These forums are supposed to be for help or info not stupid comments !
Post #515600 Mon Jan 23 2017 8:57pm
flack
No its a pain in the arse, unlike the 2.7 you have much less access as only the top part comes off, Unless you want to remove the whole lot which is a big task in itself.
It just makes the job a bit harder having to lean over the fan cowling to reach everything, there is also a lot more to remove on the3 ltr than 2.7 ltr.
Flack Thumbs Up
Post #515625 Mon Jan 23 2017 11:40pm
merlin1
thanks flack that is what i thought , there is so much going on the cowling , will leave it alone and work around , my task next week including brakes all round cheers for your help as usual 👍
Post #515662 Tue Jan 24 2017 11:40am
