Home > Maintenance & Modifications > 2010 rrs 3.0 fan housing |
Not to be a , but if you can't get the fan shroud off do you really think it's a good idea to attempt the cam belt ? |
Mon Jan 23 2017 1:42pm |
merlin1 Member Since: 16 Sep 2009 Location: cornwall Posts: 110 |
Thankyou for your useless comment , I can get the fan housing off , but if I don't need to it will save a lot of time . These forums are supposed to be for help or info not stupid comments ! |
Mon Jan 23 2017 7:57pm |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
No its a pain in the arse, unlike the 2.7 you have much less access as only the top part comes off, Unless you want to remove the whole lot which is a big task in itself.
Mon Jan 23 2017 10:40pm |
thanks flack that is what i thought , there is so much going on the cowling , will leave it alone and work around , my task next week including brakes all round cheers for your help as usual 👍 |
Tue Jan 24 2017 10:40am |
