![]() | Home > General > Not starting (a.k.a 'Deadman's Click') |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5036 ![]() ![]() ![]() |
The relay is a common fault, cheap and easy to change.
phillh Member Since: 09 Oct 2016 Location: Hertfordshire Posts: 198 ![]() ![]() ![]() |
+ 1 for the relay, swap it for another one in the engine fuse box of the same rating and see if it starts. |
The top relay (in red) is a spare.
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 ![]() ![]() ![]() |
If no better after the relay swap would plumb for the starter. Seems to be common fault. Make sure you get the mod breather kit as well. About a 30 minute job to remove the starter, but about 1 to 2 hours to get the |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9051 ![]() ![]() ![]() |
I'd go with starter. Had the same symptoms when mine last died.
RichG Member Since: 23 Nov 2012 Location: Adelaide AU Posts: 29 ![]() ![]() ![]() |
My fault diagnosis would be:
Thanks for all the suggestions |
When I first got my car I had an intermittent fault with the heater fan. When it was very cold, it didn't work but came on a little later when things had warmed up a bit.
I think the start motor relay is marked M with a circle round it.
Thanks Mr K. The bottom relay is marked 'SM'. Pulled it this morning and engine won't crank with it out so suggests you are right |
Excellent.
Shokbox Uk Member Since: 26 Jan 2017 Location: Derbyshire Posts: 5 ![]() ![]() ![]() |
very Helpful Thanks |
RRSCruiser Member Since: 02 Apr 2010 Location: West Sussex Posts: 41 ![]() ![]() |
For item 3, where are these earths please so I can check on my tdv8 I'm having some gremlins and been told to check these but I can't find them I've found one lead from the transfer case to body that's a lead type lead for rf interference but had a good look for engine earths and can't seem em 😖 |
Look for 4ga to 8ga wires leading from the engine block to places on the body. On the TDV6 from memory there is one on each side of the engine. Sometimes the nuts can come undone or water ingress can cause corrosion which stops continuity. Good luck, the TDV6 is hard enough to navigate around, I can't imagine what the TDV8 must be like! MY08 RRS TDV6, Chawton/Black, sunroof, hk, 268k km
