Home > General > Not starting (a.k.a 'Deadman's Click')
Paddi
As above. On three separate occasions in the last week or so I've turned the key to the first stop, waited for the checks to complete and the glowplug light to go out and then turned and held only to find nothing happens. No sound from the starter motor even.
On subsequent attempts it may start on the next or after several tries.
Here's what the manual has to suggest: with my comments in italics
Symptoms
The engine does
not crank (starter
motor does not
turn)
Possible causes
Gear selector not in P or N position (vehicles with automatic transmission) It's not this!
Battery unlikely - cranks over fast once it does crank
Starter relay Possibly!
Invalid key code received by central junction box (CJB) Possibly?
Harness/Connectors Possibly but unlikely since it works eventually?
Starter motor unlikely?
Ignition switch Possibly
Generator Unlikely?
Transmission control module (TCM) Unlikely, but was was recently changed
Engine control module (ECM) Would this be intermittent?
Engine seized Definitely not - not yet anyway!
I checked the battery connections and the voltage with engine off and both seemed OK (12.4 volts).
On older analogue cars I'd be suspecting the starter relay and changing it but on the RRS I think this is integral to the starter motor so not an easy thing to do as the starter is hard to get at.
The garage recently had the body off so I wonder if something is not tight - like an earth strap?
Does anyone have experience of this happening and if so what was the fix? 2008 MY Java Black TDV8 HSE
Post #514949 Wed Jan 18 2017 6:12pm
The relay is a common fault, cheap and easy to change.
Has to be Step 1
Post #514954 Wed Jan 18 2017 6:28pm
phillh
United Kingdom 2005 Range Rover Sport TDV6 HSE Zermatt Silver
+ 1 for the relay, swap it for another one in the engine fuse box of the same rating and see if it starts.
Post #514960 Wed Jan 18 2017 6:49pm
The top relay (in red) is a spare.
Try that one for the starter (if it's the same type)
[URL=]
[/URL]
Post #514961 Wed Jan 18 2017 6:51pm
Camelrock
If no better after the relay swap would plumb for the starter. Seems to be common fault. Make sure you get the mod breather kit as well. About a 30 minute job to remove the starter, but about 1 to 2 hours to get the Censored out of the engine bay and the new one in.. 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #514985 Wed Jan 18 2017 9:37pm
I'd go with starter. Had the same symptoms when mine last died.
Breather pipe essential if you go wading. Killed a couple of starters over two or three years because of this. Eventually got the breather fitted correctly - after telling the LR dealer how it should be fitted! 2012 SDV6 - it's missing a couple of cylinders
Post #514989 Wed Jan 18 2017 9:55pm
RichG
Australia 2008 Range Rover Sport TDV6 SE Chawton White
My fault diagnosis would be:
1. load test the battery!
2. replace starter relay with known good
3. check and clean engine earth linkages
4. check megafuse and positive lead from battery to alternator to starter to good continuity and no loose connections
5. remove starter and bench test. MY08 RRS TDV6, Chawton/Black, sunroof, hk, 268k km
2001 Audi A4 1.8T quattro 5mt sport, 340k km
1990 Nissan Pintara TRX, lots of mods, 438k km
Post #515015 Thu Jan 19 2017 12:55am
Paddi
Thanks for all the suggestions Very Happy
Checked the battery voltage again and after overnight it was 12.4V so not too bad.
Checked the tightness of the megafuse connections - all OK
Assuming the starter relay is R6 - (the one with a pictgram of a thunderbolted engine) I pulled it and cleaned the contact points inside. The spare one that Andy K suggested appears to be different so not tried swopping them.
Read the fault codes and found nothing that looks related. Only engine one was U0405-85 lost comms with speed sensor?
Gave the key a twist and it started instantly of course Rolling Eyes
Put battery on charge just in case but that's as far as I'm going today; it is far too cold outside for crawling about underneath with spanners. Time I delivered on that long term plan to build a huge heated garage with a two post lift.
Don't you just hate intermittent faults? Banging Head 2008 MY Java Black TDV8 HSE
Post #515088 Thu Jan 19 2017 3:45pm
phillh
When I first got my car I had an intermittent fault with the heater fan. When it was very cold, it didn't work but came on a little later when things had warmed up a bit.
I traced this to the relay which I replaced and it has been fine ever since.
It was only around a fiver from LR dealer in Welwyn Garden City, might be a good investment. Thumbs Up
Post #515098 Thu Jan 19 2017 4:50pm
I think the start motor relay is marked M with a circle round it.
Bottom left in the pic ?
M for motor
or is it SM for starter motor ?
Post #515108 Thu Jan 19 2017 7:09pm
Paddi
Thanks Mr K. The bottom relay is marked 'SM'. Pulled it this morning and engine won't crank with it out so suggests you are right Thumbs Up
Popped open the relay to have look inside and the contact points showed signs of blackening . For now I've cleaned up the contacts and since had two clean starts. Time will tell.
Battery by the way seems good; after charging and then standing overnight in sub zero conditions it read 12.6 volts.
If the relay isn't the cause of the fault then the next most likely culprit is the starter motor solenoid? Way too cold to be messing with that though. 2008 MY Java Black TDV8 HSE
Post #515245 Fri Jan 20 2017 10:27pm
Excellent.
Don't forget about the spare relay if required.
Post #515246 Fri Jan 20 2017 10:44pm
Shokbox Uk
United Kingdom 2009 Range Rover Sport 3.0 TDV6 HSE Izmir Blue
very Helpful Thanks
Post #516326 Mon Jan 30 2017 9:21pm
RRSCruiser
2007 Range Rover Sport TDV8 HSE Santorini Black
For item 3, where are these earths please so I can check on my tdv8 I'm having some gremlins and been told to check these but I can't find them
I've found one lead from the transfer case to body that's a lead type lead for rf interference but had a good look for engine earths and can't seem em 😖
Post #516336 Mon Jan 30 2017 10:16pm
RichG
Look for 4ga to 8ga wires leading from the engine block to places on the body. On the TDV6 from memory there is one on each side of the engine. Sometimes the nuts can come undone or water ingress can cause corrosion which stops continuity. Good luck, the TDV6 is hard enough to navigate around, I can't imagine what the TDV8 must be like! MY08 RRS TDV6, Chawton/Black, sunroof, hk, 268k km
Post #516337 Mon Jan 30 2017 10:19pm
