![]() | Home > General > HDC Fault System Not Available with 3 warning lights |
Fish Member Since: 29 Jan 2014 Location: Glasgow Posts: 60 ![]() ![]() ![]() |
Hi there,
Evans Garage in Dorset http://www.evansgarage.co.uk/
German-wheels Member Since: 23 Jul 2016 Location: Bournemouth Posts: 88 ![]() ![]() ![]() |
Thanks for the replies, will check out those places for a scan. I've read quite a bit about the brake switch and also about the steering angle sensor being calibrated. Hopefully it will be one of these as they are easy fixes.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9055 ![]() ![]() ![]() |
Lack of a battery cover shouldn't be a problem for the ECU or TCM unless someone has been jet washing in the engine bay. 2012 SDV6 - it's missing a couple of cylinders
Thanks for the reply, good to know! Think I'll pick up a cover anyway just because it will look neater under there.
CRACKA Member Since: 16 Sep 2014 Location: Hallam Victoria 3803 Posts: 170 ![]() ![]() ![]() |
I think I can help as I had exactely the same symptoms. I had it fixed recently but I been looking for the invoice for about an hour and its driving me mad that I can't find it. |
I just recently changed my lower front suspension arms and track rod ends and I was getting these indications too as I could see on the steering wheel that I had not got it quite centred (steering wheel centre was off at about 11 o'clock). You are saying that the fault is intermittent but mine was every time I drove, after a couple of minutes it would alarm as the sensors were picking up that the steering angle didn't correspond to the wheel speed sensors.
Hi, I found the invoice and details.
Thanks CRACKA, look forward to receiving the info if you find it.
Thanks CRACKA, appreciate the time taken to look for it, the steering angle calibration is something that I'm hoping will work so that's really helpful. |
