Home > General > HDC Fault System Not Available with 3 warning lights |
Fish Member Since: 29 Jan 2014 Location: Glasgow Posts: 60 |
Hi there,
Thu Dec 29 2016 12:51pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
Evans Garage in Dorset http://www.evansgarage.co.uk/
Thu Dec 29 2016 1:07pm |
German-wheels Member Since: 23 Jul 2016 Location: Bournemouth Posts: 88 |
Thanks for the replies, will check out those places for a scan. I've read quite a bit about the brake switch and also about the steering angle sensor being calibrated. Hopefully it will be one of these as they are easy fixes.
Thu Dec 29 2016 7:03pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8978 |
Lack of a battery cover shouldn't be a problem for the ECU or TCM unless someone has been jet washing in the engine bay. 2012 SDV6 - it's missing a couple of cylinders
Thu Dec 29 2016 7:23pm |
Thanks for the reply, good to know! Think I'll pick up a cover anyway just because it will look neater under there.
Thu Dec 29 2016 7:50pm |
CRACKA Member Since: 16 Sep 2014 Location: Hallam Victoria 3803 Posts: 170 |
I think I can help as I had exactely the same symptoms. I had it fixed recently but I been looking for the invoice for about an hour and its driving me mad that I can't find it.
Thu Dec 29 2016 9:08pm |
I just recently changed my lower front suspension arms and track rod ends and I was getting these indications too as I could see on the steering wheel that I had not got it quite centred (steering wheel centre was off at about 11 o'clock). You are saying that the fault is intermittent but mine was every time I drove, after a couple of minutes it would alarm as the sensors were picking up that the steering angle didn't correspond to the wheel speed sensors.
Thu Dec 29 2016 9:29pm |
Hi, I found the invoice and details.
Thu Dec 29 2016 11:16pm |
Thanks CRACKA, look forward to receiving the info if you find it.
Thu Dec 29 2016 11:20pm |
Thanks CRACKA, appreciate the time taken to look for it, the steering angle calibration is something that I'm hoping will work so that's really helpful. |
Thu Dec 29 2016 11:21pm |
