Home > In Car Electronics > Parking aid/reverse camera unavailable?
abilover
England 2012 Range Rover Sport SDV6 HSE Fuji White
Hi everyone, newbie here, owned my RRS for about a month, it's 12MY and I love it. Been faultless up to now.... But... 1st problem cropped up today when reversing onto my drive. No parking aid or camera just an error message. Locked it up and let it go to sleep and then later had to pop to the shop, and hey presto all is restored when parking at the shop. Got back in and went to my mothers and selected reverse and got the error message again? Grrrr looked on the forum and could only find info about retro fitting? Can anyone help me?
Post #507344 Sat Oct 08 2016 2:42pm
Had this on mine after been playing about with buttons and switches. Switched it off locked the car and left it for hour or so to go to sleep etc. came back and all had reset it's self, worth a try.
Post #507352 Sat Oct 08 2016 4:49pm
abilover
Just an update on my progress on trying to fix my problem with my parking sensors/rear camera. Yes I get the long beep when starting the car and yes I get the flashing orange light above the front PDC button then I get the message pictured on my opening post.
I have read numerous posts on the forum regarding faulty sensors, damaged looms, chafed wires front and rear. So today, armed with my iid tool, I set about trying to find what's causing it.
I plugged it in and sure enough got a fault code (pictured below) so I removed the NSR light cluster and disconnected the rear loom, cleared the fault and tried again. The iid tool read the ecu and the fault appears again? I then removed the OSF headlamp and disconnected the front loom, cleared the fault and let the iid tool read the ecu again and the fault is still there?
How can the fault be still there with both front and back looms disconnected?
Has anyone any ideas where I need to look next?
Cheers in advance guys
Post #514458 Sat Jan 14 2017 6:37pm
abilover
Anyone? Very Happy
No seriously, I'm guessing no one has come across this fault before? So I am planning on attacking this on Saturday and think it only right in the spirit ot the forum that I should be making notes and taking photos so I can maybe help someone else in the future.
Armed with my iid tool, watch this space!
Post #515137 Thu Jan 19 2017 10:50pm
It says "Function LED"
well there is an LED in the switch.
...but that shouldn't cause it to all shut down
Don't know what it's referring to though.
Post #515180 Fri Jan 20 2017 11:49am
abilover
yeah I thought that?
But seems strange that it would take the system out. Wish it was just a faulty switch!
Appreciate your reply Andy,
I'll definitely get to the bottom of it Thumbs Up
Post #515184 Fri Jan 20 2017 12:09pm
Socast
The DTC B1B54:12 means there is a problem with the PAM system status indicator/switch. Either the circuit between PAM module and the switch/LED is damaged/disconnected, or the Switch/LED is damaged.
Post #515195 Fri Jan 20 2017 2:41pm
abilover
Wow, that's great information!
I've just got in from work early and was going to start looking. I think I'll start by taking the NSR trim off and locate the PDC module and go from there.
Thanks very much for that Thumbs Up
Mark
Post #515196 Fri Jan 20 2017 2:47pm
abilover
Small update
Took off the NSR trim panel and located the Parking aid module, had a good look around to see if there was any loose plugs or wires but alas no. Checked any damaged wires, but all looked fine.
Plugged the iid tool in again and checked for faults again and it's still the same as before. Checked the live values of the switch and pressing the switch the tool says active, releasing my finger and it says inactive so it's obviously making a difference but not latching? It says that the LED is inactive and pressing the switch does not make the LED flash? Could it be the switch? Could it be the module? Big Cry
Look again tomorrow, anything to avoid going to the main dealer!
Post #515215 Fri Jan 20 2017 6:16pm
Switch isn't meant to latch.
I thought you would've able to turn the led on and off with the iid.
Maybe not
Post #515220 Fri Jan 20 2017 7:12pm
Have a read of codes in other modules.
Is there one for the display ? Camera?
Post #515221 Fri Jan 20 2017 7:14pm
abilover
Thanks Andy, up and at it tomorrow!
Still learning with the iid tool, I know there are guys on here that could trace the fault in a breath, but I guess that's what it's all about, it's all experience and we pass it on to each other through this forum.
Maybe I'll have to pay in the end, but for now I'll keep trying!
Post #515222 Fri Jan 20 2017 7:52pm
abilover
Well I have to admit that I might have to let the professionals deal with this!
Spent a full day trying to trace the fault and I've only just come in.
Firstly I plugged in my iid tool to make sure the symptoms were the same, and they were, the car gives me a 3 sec 1500HZ bleep but NO flashing led when ignition is switched on and flashing led when reverse is selected.
Unplugged the rear bumper loom - still the same
Unplugged the front bumper loom - still the same
Removed the rear bumper continuity test the rear loom check sensor connections and refit - still the same
Removed the front bumper continuity test the front loom check sensor connections and refit - still the same
Connected the iid tool and started to check live values.
It says there is a fault - but we already know this
The switch on the dash works and the live value changes when you push it in and out
The led says inactive in park but flashes on and off in reverse
The rear sounder says active
The front sounder says INACTIVE and doesn't change could this be the fault? Maybe? But I read on here that the door open warning and the bongs for lights left open warnings come from the front sounder? I don't know if this is true?
Has anyone had trouble with the front parking aid speaker/sounder?
Post #515361 Sat Jan 21 2017 8:09pm
I don't think it's your ability it's just an unusual fault.
The only thing I sometimes suggest is to change the options to say the fronts aren't fitted to see if that narrows anything down
Post #515369 Sat Jan 21 2017 8:32pm
abilover
Seem to have drawn a blank wringing anymore information out of the forum, so I'm still battling away!
Can anyone confirm wher the rear parking sounder/speaker is located? Is it the item in the first picture?
Thanks
Post #515508 Sun Jan 22 2017 9:24pm
