Home > General > Can you identify this part? |
darrenmcneill Member Since: 05 Oct 2014 Location: Whitworth Posts: 442 |
Hi,
Fri Sep 30 2016 12:09pm |
That's your suspension compressor 2008 MY Java Black TDV8 HSE
Fri Sep 30 2016 12:27pm |
Darren
Fri Sep 30 2016 12:36pm |
I've got an orange suspension fault light, and the noise stops once the light pings on in the dash.
Fri Sep 30 2016 1:40pm |
Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378 |
Sounds like it's leaking from a cracked cap, have a read through this lot,
Fri Sep 30 2016 8:52pm |
Cheers,
Sat Oct 01 2016 3:53am |
Have you done the spray test first, just a bit of car shampoo and water in a bottle, better to be sure first. If you get no response from your pm, look on eBay for Range Rover compressor rebuild kits, they vary in price I went with a complete kit from X8R. But to be honest I think I could have gotten away with just the dryer filters and cap, as the piston seals an o rings were fine. But I changed them for good measure as I had the parts to hand.
Sat Oct 01 2016 6:58am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4966 |
Could be an air valve block seal too. |
Sat Oct 01 2016 7:03am |
Finally ordered now, thanks for the advice. 2006 HSE for Sale - £7,499 (Manchester) http://www.rrsport.co.uk/forum/topic46383.html |
Wed Dec 07 2016 8:36pm |
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 |
What have you ordered? as you will need the air pipe couplers as well 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater ))) |
Thu Dec 08 2016 10:30am |
Bloody hell! Best get those ordered as well 2006 HSE for Sale - £7,499 (Manchester)
Thu Dec 08 2016 10:53am |
The 3 air pipes that attach to the unit, only one will come off, the one under pressure, the rear two with are supply and return will never come off, maybe 1 in a 1000 will. When you cut the pipes, make sure you leave enough room to push the new connector on 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater ))) |
Thu Dec 08 2016 11:02am |
