![]() | Home > General > Can you identify this part? |
darrenmcneill Member Since: 05 Oct 2014 Location: Whitworth Posts: 442 ![]() ![]() ![]() |
That's your suspension compressor 2008 MY Java Black TDV8 HSE
Darren
I've got an orange suspension fault light, and the noise stops once the light pings on in the dash.
Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378 ![]() ![]() ![]() |
Sounds like it's leaking from a cracked cap, have a read through this lot,
Cheers,
Have you done the spray test first, just a bit of car shampoo and water in a bottle, better to be sure first. If you get no response from your pm, look on eBay for Range Rover compressor rebuild kits, they vary in price I went with a complete kit from X8R. But to be honest I think I could have gotten away with just the dryer filters and cap, as the piston seals an o rings were fine. But I changed them for good measure as I had the parts to hand.
Could be an air valve block seal too. |
Finally ordered now, thanks for the advice. 2006 HSE for Sale - �7,499 (Manchester) http://www.rrsport.co.uk/forum/topic46383.html |
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 ![]() ![]() ![]() |
What have you ordered? as you will need the air pipe couplers as well 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater |
Bloody hell! Best get those ordered as well 2006 HSE for Sale - �7,499 (Manchester)
The 3 air pipes that attach to the unit, only one will come off, the one under pressure, the rear two with are supply and return will never come off, maybe 1 in a 1000 will. When you cut the pipes, make sure you leave enough room to push the new connector on 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater |
