Home > General > Can you identify this part?
darrenmcneill
England 2006 Range Rover Sport TDV6 HSE Tonga Green
What is this part?
When I start the car I can hear it kick in (to me it sounds like a mini pump). Is it something to do with the suspension?
It comes on for a few mins, switches off, then comes back on (I can hear it humming).
Just want to check that it should be doing this, and if not what should I do.
Help appreciated!
 2006 HSE for Sale - £7,499 (Manchester)
http://www.rrsport.co.uk/forum/topic46383.html
Post #506770 Fri Sep 30 2016 12:09pm
Paddi
That's your suspension compressor 2008 MY Java Black TDV8 HSE
Post #506773 Fri Sep 30 2016 12:27pm
SRE
Spain
Darren
Leave the car in access mode when you park up, then see if it still makes the same noise In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #506774 Fri Sep 30 2016 12:36pm
darrenmcneill
I've got an orange suspension fault light, and the noise stops once the light pings on in the dash.
So, is this going to be straight forward.... Whistle
Suspension is fine before the dashboard ding, goes up/down etc. Fault resets itself once car has been off, so the unit works, it just sounds like it's trying to do something (if that makes sense?) 2006 HSE for Sale - £7,499 (Manchester)
Post #506783 Fri Sep 30 2016 1:40pm
Danv8
United Kingdom 2009 Range Rover Sport TDV6 HSE Lux Alaska White
Sounds like it's leaking from a cracked cap, have a read through this lot,
http://www.rrsport.co.uk/forum/topic45553.html
Post #506809 Fri Sep 30 2016 8:52pm
darrenmcneill
Cheers,
Just PM'd to see if there are any caps left 2006 HSE for Sale - £7,499 (Manchester)
Post #506816 Sat Oct 01 2016 3:53am
Danv8
Have you done the spray test first, just a bit of car shampoo and water in a bottle, better to be sure first. If you get no response from your pm, look on eBay for Range Rover compressor rebuild kits, they vary in price I went with a complete kit from X8R. But to be honest I think I could have gotten away with just the dryer filters and cap, as the piston seals an o rings were fine. But I changed them for good measure as I had the parts to hand.
This is the full complete kit
http://www.ebay.co.uk/itm/For-Land-Rover-D...Sw8d9Uwl94
Just the end cap, (can be changed with out removing the unit, although a bit fiddly)
http://www.ebay.co.uk/itm/For-Land-Rover-D...SwNSxVUgGD
Cap and dryer kit
http://www.ebay.co.uk/itm/For-Land-Rover-D...Swm8VUwlz0
Post #506821 Sat Oct 01 2016 6:58am
Could be an air valve block seal too.
Post #506822 Sat Oct 01 2016 7:03am
darrenmcneill
Cap and dryer kit
Finally ordered now, thanks for the advice. 2006 HSE for Sale - £7,499 (Manchester)
Post #511773 Wed Dec 07 2016 8:36pm
shakeapaw
What have you ordered? as you will need the air pipe couplers as well 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #511809 Thu Dec 08 2016 10:30am
darrenmcneill
Bloody hell! Best get those ordered as well 2006 HSE for Sale - £7,499 (Manchester)
Post #511816 Thu Dec 08 2016 10:53am
shakeapaw
The 3 air pipes that attach to the unit, only one will come off, the one under pressure, the rear two with are supply and return will never come off, maybe 1 in a 1000 will. When you cut the pipes, make sure you leave enough room to push the new connector on 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #511818 Thu Dec 08 2016 11:02am
