![]() | Home > General > SUSPENSION PROBLEM - SOUNDS LIKE A U/S SHOCK ABSORBER... |
The doc Member Since: 31 Oct 2006 Posts: 1173 ![]() ![]() |
Roll on Tuesday! |
rrsjo Member Since: 28 Nov 2006 Location: North Cambs Posts: 551 ![]() ![]() ![]() |
My car goes into another garage to check out my "problem" - its due back Tuesday... |
And what problem would that be Doc!!! |
Fingers crossed for me please guys - Hillendale seem the best people and are very much up for the job! |
jk516696 Member Since: 15 Mar 2006 Location: uk Posts: 17 ![]() ![]() |
My RRS sounds like a 20 year old Escort with worn shocks |
Thanks for letting us know!
Are all these RRS fitted with the Dynamic Response system, or are we gettng reports of other front suspension knocking noises, as well as those caused by the ARC valve on the Response?
Singletrack Member Since: 07 May 2006 Location: Belgium - Lasne Posts: 330 ![]() ![]() ![]() |
I don't have DR and have no knocking or noise problems from the suspension. As to which models are fitted, as far I know, all Supercharged are fitted - prior to the 2007 MY, it was an option on the other models (not sure about the normally aspirated V-eight). In 2007, all HSE trims including the TDV6 have DR. At least in the Belgian market. This will vary from market to market with the U.S. getting the most toys included.
Another point is that 85% of RRS that I see are HSE or higher.
Kaine Member Since: 26 May 2006 Location: Hills of Shropshire Posts: 8902 ![]() ![]() |
we dont know this is the case - my 07MY with DR doesn't have any knocking noise at all - following this thread from the start I'm still not convinced this problem is 'inherant' - it still could well be a manufacturing fault IMO |
