Home > Technical > Suspension ACCESS height problem. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4974 |
Have you had the suspension lowered?, as have come across this on vehicle where the suspension has ben reset and lowered too much and thinks it has bottomed out. Could try re-setting to factory height configuration using Gap tool or just try experimenting raising the ride height a couple of mil at a time to see if that make any difference.
Sat Aug 13 2016 8:56am |
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 138 |
Vehicle is bog standard. Yes, perhaps I should read the ride heights to see what the height sensors are showing at the bottom. |
Sat Aug 13 2016 8:58am |
In normal ride height, what is the measurement between centre of range rover wheel centre and lower edge of wheel arch?, should be some where between 461mm Front + or - 12mm and Rear 465mm + or minus 13mm
Sat Aug 13 2016 9:06am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
I had a similar problem although between offroad and normal.
Sat Aug 13 2016 9:12am |
Johnski Member Since: 02 Sep 2015 Location: North Wales & North Yorkshire Posts: 1407 |
........and some useful information passed onto me before, don't forget when altering height it affects the other heights, so if you lower by 15mm on access, then your normal and off road settings will also be 15mm lower. Same on raising heights subject to bottoming out or trying to high. John
Sat Aug 13 2016 9:10pm |
Tried all the above suggestions except dismantling anything.
Mon Aug 15 2016 11:44pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8982 |
Probably a sensor issue then. When you lower the vehicle, watch the 4x4 screen to see if a red bar shows above one of the wheels just before it starts to raise back up. 2012 SDV6 - it's missing a couple of cylinders
Tue Aug 16 2016 8:42am |
I suspect there are other things which can cause the car to think it has come aground.
Tue Aug 16 2016 11:07am |
I am going to be looking at the height sensors and valves next, possibly tomorrow if I have time.
Tue Aug 16 2016 2:50pm |
Front and rear valve blocks. Rear is on the left rear suspension turret. Front is behind the front right bumper. Access through the wheel arch 2012 SDV6 - it's missing a couple of cylinders
Tue Aug 16 2016 4:26pm |
I found the Rear one a nightmare to remove/refit |
Tue Aug 16 2016 4:50pm |
I looked at doing it once but decided a ramp would make the whole job easier as you can come at it from the spare wheel bay then. Got a garage to do it in the end. 2012 SDV6 - it's missing a couple of cylinders
Tue Aug 16 2016 5:41pm |
Wed Aug 17 2016 7:44am |
It looks like the contents of the compressor dryer has turned to powder form and deposited all over the suspension components. I need to replace the desiccant and filters of the compressor dryer.
Thu Aug 18 2016 1:36am |
