Home > Technical > Actuator sticking
ShooterNeil
Actuator sticking
Hi all how do I get in to clean and oil my actuators TDV8. I have a flat code of p132B-22
Actuators sticking ? Car is fine when cold no falt comes up its only when it's turned off then on after popping in the shop and at normal working temp it then has the falt and limps home 61 AB 5.0 supercharged rocket
07 HSE TDV8 with lots of toys EGR removed BAS remap
56 HSE WAS FULL OF PROBLEMS
Post #501237 Tue Jul 19 2016 7:56pm
Farmer Mel Tucker
United Kingdom 2007 Range Rover Sport TDV6 HSE Buckingham Blue
Hi Neil, did you get to the bottom of your problem? I'm interested as I have the same code recurring.
I've just replaced both EGR valves (diff code) but still get the fault - with no lights - engine system fault - and my RR acts like a tortoise on sedative
Frustrating is not the word!
Having read up a bit, P132B is def a turbo fault, but knowing my luck it'll be royal stuffed! Evil or Very Mad
cheers
Post #513206 Fri Dec 30 2016 6:37pm
ShooterNeil
Hi Mel
After having the codes read I was told you can't just clean and oil the actuators it's body off and normally new turbos
So I went home ordered some high temperature penetrating oil 18£ stripped as much as I was Comfortable with out the engine bay and under the wheel arch then got a long straw on the oil can and drown it all around the turbo with the oil turning the key on and off this helped work in the oil as the actuator moved
Let oil drip off over night and I have not has a problem since then
Have you had the boost pressure tested on the turbos is the cat ok not blocked as this happens on the lorrys at work
Good luck 61 AB 5.0 supercharged rocket
Post #513219 Fri Dec 30 2016 8:10pm
Farmer Mel Tucker
Thanks Neil. I haven't had the pressures read yet, just waiting for my mechanic to finish his festive season! lol
As its an intermittent fault, I am hoping that I can do the same as you and get it cleaned out. I will probably trade it in thereafter as I'm not going to be able to afford a new turbo anytime soon which is pretty depressing. I will keep you posted and I appreciate you coming back to me. Happy New Year Thumbs Up
Post #513258 Sat Dec 31 2016 7:25pm
shakeapaw
the other way to do it it too get a coat hanger and move the actuators up and down to free them, while spraying oil on them.
full access height, jack it up and remove belly pan, if you lie on your back you can just about see them 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #513337 Mon Jan 02 2017 12:15pm
Farmer Mel Tucker
Thanks guys, really appreciate all your advice ! Smile
Post #513411 Tue Jan 03 2017 10:10am
ShooterNeil
Keep us up to date Mel 61 AB 5.0 supercharged rocket
Post #513463 Tue Jan 03 2017 6:57pm
Farmer Mel Tucker
Will do ! Its back with him today so he may have looked at it today or will do tmw. I think I may have a split in the pipe work as its smoking like a Censored when I start it. Be back in a day or so.....
Post #513466 Tue Jan 03 2017 7:12pm
Farmer Mel Tucker
Hello! hope all are well
So I got my car back, and we are definitely better! I was going to have a crack myself, but then decided better of it so mechanic had it and my actuator is now free! lets hope it stays that way!
Do you recommend a good 'oiling' at every service?
I'm so glad I'm not acting like a tortoise any more, so nice to put my foot down and something happen!
I got new tyres today too so for now....things are good....
I'm not going to count my chickens tho! lol Laughing
Post #514053 Tue Jan 10 2017 5:20pm
ShooterNeil
It's got to be worth a spray of oil at service time
Nice to here it's ok now 61 AB 5.0 supercharged rocket
Post #514072 Tue Jan 10 2017 8:58pm
Paddi
Well done boys. Another example of the forum helping a fellow owner to save much cash hopefully. Thumbs Up 2008 MY Java Black TDV8 HSE
Post #514087 Tue Jan 10 2017 9:54pm
Mani
England 2008 Range Rover Sport TDV8 HSE Stornoway Grey
Hi Pal would you please be kind enough to tell me the name of the high temp oil you used and where you bought it from? and also what side wheel arch cover did you remove near side or off side?
Regards
Mani
Post #514109 Wed Jan 11 2017 4:26am
passenger side on the TDV6
I guess both sides on a twin turbo V8
Post #514127 Wed Jan 11 2017 12:08pm
Mani
thanks pal Thumbs Up
Post #514128 Wed Jan 11 2017 12:16pm
Farmer Mel Tucker
Mine worked, for a whole day
not a happy bunny Sad
I have a workshop at home so I think I'm gonna get it cleared, get a heater, and some oil - what's best Neil? and have a crack myself
Geez I surely can't do any worse...
Is there anything on YouTube anyone know?
Thanks all for the help, its definitely the actuator (I assume I only have one?) so being on this forum has been great
Post #514293 Thu Jan 12 2017 8:55pm
