Home > Maintenance & Modifications > 4.4 petrol remap |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 |
Below the threshold of actual relevance. Regards etc.,
Wed Apr 27 2016 4:48pm |
There were so few Petrol 4.4V8's sold in the UK/Europe that unfortunately it is the one variant that there is very little info about on the forum. Buyers prefered the better performance of the S/C and they have similar fuel consumption of the NA 4.4 V8. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Wed Apr 27 2016 6:32pm |
Mmarques Member Since: 09 Apr 2016 Location: Oxfordshire Posts: 76 |
Oh really? would it be relevant asking about the remaps people have had on their 4.2 SC then? or is it totally irrelevant? |
Wed Apr 27 2016 7:23pm |
"Relevance" as in "noticeability".
Wed Apr 27 2016 8:30pm |
Thanks Thewojtek for the advice and info, definitley sounds like you know your stuff! Looks like Ill have to scrap that idea then and move on.
Thu Apr 28 2016 1:58pm |
I don't know if you are aware that there were a handful (IIRC 8 in total) 4.4S/C's built by LR for development but the engine longevity was so short due to the thin cylinder walls that the bore was sleeved down and capacity reduced to 4.2 litres. Virtually all the development cars ended up in the great LR crusher but I know of one that is still locked up in a shed in Scotland....... You could try DMS and see if they do a remap for it, but remember to tell them that it is a 4.4 Petrol otherwise they will think you have the 4.4SDv8............. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thu Apr 28 2016 2:26pm |
More or less this: What I like about the Disco3 is that is whisper silent compared to my SC (which has exactly this mod done). However, what I like about the SC (apart from the 100 HP improvement over the Disco) is that is loud as a thunder when I floor it. Regards etc., Wojtek --- WAS: 2006 RRS Supercharged IS: 2010 RRS TDV8 HSE |
Thu Apr 28 2016 3:19pm |
Loud as thunder when you floor it, Mmmmmm I like haha. Just watched the video, so could I just delete/cut out the turtle shaped muffler or would I also have to remove the rear silencers/mufflers? |
Thu Apr 28 2016 3:32pm |
The usual procedure on a RRS is to remove #7 on the exhaust system.
Thu Apr 28 2016 3:48pm |
Just been reading on an US landy forum and they seemed to have removed/deleted #8? whats the difference in removing #7 or #8?
Thu Apr 28 2016 4:01pm |
Removing a muffler does not affect emmisions tests, so you're safe with that.
Thu Apr 28 2016 5:43pm |
So are both 7 & 8 classed as mufflers? Im assuming having both removed would be too loud? How did you do yours, did you just cut it out and have a straight pipe (2 straight pipes) welded in? have you got a video of how yours sounds? |
Thu Apr 28 2016 6:15pm |
Yes, exactly. Two straight 2.25" pipes instead of the muffler (one is called "resonator". can't remember which one).
Thu Apr 28 2016 8:52pm |
Very tempted by this. Whats it like when your doing motorway driving, is it a drone or is it not that bad?
Fri Apr 29 2016 12:15pm |
