Home > General > Another Newbie |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
I'd go for the Indy's one and ask for a belt to be fitted.
Fri Apr 22 2016 6:11am |
What makes you think the RRS will be less of a money pit? It is a disco3 in a party frock, they are almost the same car under the skin! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Fri Apr 22 2016 6:17am |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
Personally I'd be looking at the TDV8 give it a road test ! Then see if you can leave that exhaust note behind 2008 G4 RRSport TDV8 current
Fri Apr 22 2016 9:14am |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
0 posts??!!
Fri Apr 22 2016 9:43am |
^ What Camelrock says, TDv8 was the diesel motor RRS should have had from day 1. I have run the 2.7TDv6, 3.6TDv8 and a FFRR Tdv8 3.6 Vogue.............. The RRS TDv8 was the best of the lot, could get up and go, smooth and quiet and most important of all, unlike the same motor in the FFRR, it could stop amazingly quickly on the Brembo brakes that the FFRR version didn't have. I made a huge mistake swapping the TDv8 RRS for the TDv8 L322 Vogue, handling wise no comparison.
Fri Apr 22 2016 9:46am |
HFM66 Member Since: 21 Apr 2016 Location: Ascot, Berkshire Posts: 1 |
Thanks for the comments and apologies about no posts... I've been in a meeting all day, honest...
Fri Apr 22 2016 9:29pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8974 |
They weren't having a go because you hadn't replied, they were pointing out that you'd made a post but the post counter on your profile showed a zero. Which is odd. Having made two posts, your counter shows 1. Still odd. We're a bit sad like that in here! 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Sat Apr 23 2016 9:09am |
That's the problem with buying expensive vehicles at the tail end of their life - if any previous owner has skimped on maintenance you're likely to have to pick up the pieces. They are complex bits of kit, take more than their fair share of TLC to keep running and the bits are generally expensive. All a recipe for maintenance to be done on a "I'll do that at the next service, maybe" basis. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Sat Apr 23 2016 9:16am |
Rivet counters 2008 G4 RRSport TDV8 current 2009 TDCi 90 current 2018 Discovery 5 HSE lux current 1994 Dakar current |
Sat Apr 23 2016 9:18am |
tonkatoy Member Since: 28 Aug 2016 Location: kent Posts: 19 |
I'll put my money on the fact if you drive the TDV8 you'll buy it.
Fri Sep 09 2016 5:04pm |
Your making all the right noises keep it up, I love the v8 as well 2008 G4 RRSport TDV8 current
Fri Sep 09 2016 6:57pm |
