![]() | Home > General > Another Newbie |
I'd go for the Indy's one and ask for a belt to be fitted.
What makes you think the RRS will be less of a money pit? It is a disco3 in a party frock, they are almost the same car under the skin! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Personally I'd be looking at the TDV8 give it a road test ! Then see if you can leave that exhaust note behind |
0 posts??!!
^ What Camelrock says, TDv8 was the diesel motor RRS should have had from day 1. I have run the 2.7TDv6, 3.6TDv8 and a FFRR Tdv8 3.6 Vogue.............. The RRS TDv8 was the best of the lot, could get up and go, smooth and quiet and most important of all, unlike the same motor in the FFRR, it could stop amazingly quickly on the Brembo brakes that the FFRR version didn't have. I made a huge mistake swapping the TDv8 RRS for the TDv8 L322 Vogue, handling wise no comparison.
HFM66 Member Since: 21 Apr 2016 Location: Ascot, Berkshire Posts: 1 ![]() ![]() |
Thanks for the comments and apologies about no posts... I've been in a meeting all day, honest...
They weren't having a go because you hadn't replied, they were pointing out that you'd made a post but the post counter on your profile showed a zero. Which is odd. Having made two posts, your counter shows 1. Still odd. We're a bit sad like that in here! ![]() 2008 TDV8 - it was a labour of love and is much missed |
That's the problem with buying expensive vehicles at the tail end of their life - if any previous owner has skimped on maintenance you're likely to have to pick up the pieces. They are complex bits of kit, take more than their fair share of TLC to keep running and the bits are generally expensive. All a recipe for maintenance to be done on a "I'll do that at the next service, maybe" basis. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Rivet counters ![]() ![]() 2009 TDCi 90 current 2018 Discovery 5 HSE lux current 1994 Dakar current |
tonkatoy Member Since: 28 Aug 2016 Location: kent Posts: 19 ![]() ![]() ![]() |
I'll put my money on the fact if you drive the TDV8 you'll buy it.
Your making all the right noises keep it up, I love the v8 as well |
