Home > Maintenance & Modifications > 2.7 TDV6 Oil Pump Replacement
Ian M
United Kingdom 2005 Range Rover Sport TDV6 HSE Zambezi Silver
Hi guys,
When replacing the oil pump, is the bottom crankshaft pulley on a key way? or do you need to use the timing pin, just trying to workout if I need to fit the pin before undoing the main crankshaft bolt to remove the cambelt crankshaft pulley.
Thanks
Ian
Post #494018 Wed Apr 20 2016 12:07pm
Ian M
Found the answer to my own question, no woodruff key in the crank shaft
Post #494020 Wed Apr 20 2016 12:47pm
You may want to check if the locking pin is designed to withstand the force of you undoing the bolt. They usually aren't.
You might want to loosen the bolt before disassembling the cambelt. You might want to do some more research first
Post #494036 Wed Apr 20 2016 6:37pm
DerrekL
How did you eventually get the crankshaft pulley off. Does the bolt come off clockwise or anti-clockwise?
Cheers RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #527526 Sat Jun 03 2017 3:31pm
Disco_Mikey
Normal thread, but it's torqued FT! Thumbs Up
Post #527529 Sat Jun 03 2017 4:02pm
DerrekL
Thanks DM, I eventually got the crankshaft pulley off, tight bolt!!!!, but see no woodruff key system on the crankshaft end itself, but there is a key system on the pulley wheel that I removed, how's that works surely it isn't just the force of the bolt that is holding it on?
P38 4.6 HSE V8
Post #527635 Mon Jun 05 2017 9:46am
garrycol
Australia
Yes it is - just the torque of the bolt holds the pulley in place. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #527636 Mon Jun 05 2017 10:35am
DerrekL
WOW! OK that seems insane but explains that side of things then thanks. Any idea what the key/notches on the actual crank pulley do/are for then?
P38 4.6 HSE V8
Post #527637 Mon Jun 05 2017 10:39am
