Home > Maintenance & Modifications > 2.7 TDV6 Oil Pump Replacement |
Ian M Member Since: 19 Mar 2016 Location: Wolverhampton Posts: 2 |
Found the answer to my own question, no woodruff key in the crank shaft |
Wed Apr 20 2016 12:47pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
You may want to check if the locking pin is designed to withstand the force of you undoing the bolt. They usually aren't.
Wed Apr 20 2016 6:37pm |
DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240 |
How did you eventually get the crankshaft pulley off. Does the bolt come off clockwise or anti-clockwise?
Sat Jun 03 2017 3:31pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
Normal thread, but it's torqued FT! |
Sat Jun 03 2017 4:02pm |
Thanks DM, I eventually got the crankshaft pulley off, tight bolt!!!!, but see no woodruff key system on the crankshaft end itself, but there is a key system on the pulley wheel that I removed, how's that works surely it isn't just the force of the bolt that is holding it on?
Mon Jun 05 2017 9:46am |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1067 |
Yes it is - just the torque of the bolt holds the pulley in place. 07MY RRS TDV6
Mon Jun 05 2017 10:35am |
WOW! OK that seems insane but explains that side of things then thanks. Any idea what the key/notches on the actual crank pulley do/are for then?
Mon Jun 05 2017 10:39am |
