Home > Detailing & Car Cleaning > Restoring plastic trim
adsymck
Hi all,
Spent the day giving my TDV8 Java Black, a lovely clean today.
What products would you suggest for the plastic trim between the back windows and boot? I used Autosmart bumper treatment today and it wasn't very good.
Thanks Thumbs Up
Post #493252 Sun Apr 10 2016 6:43pm
adsymck
Post #493253 Sun Apr 10 2016 6:45pm
Gerd1986
gtechniq c4 permanent trim restorer
Pricey but well worth it!
Post #493267 Sun Apr 10 2016 10:08pm
adsymck
Thanks Gerd1986.
Is that the C4 stuff?
Post #493269 Sun Apr 10 2016 10:11pm
Socast
I bought some of this:
http://www.amazon.co.uk/Forever-Products-B...ge_o09_s00
Works well, I was going to use it on the pillar plastics but it leaves brush marks (it's basically black paint) so cleaned it off. I applied mine 2 months ago and I'm still impressed with the results.
Post #493283 Mon Apr 11 2016 8:49am
Gerd1986
Yup the C4 stuff, use sparingly though. A little goes a long way!
Post #493284 Mon Apr 11 2016 8:51am
ragpicker
United Kingdom 2008 Range Rover Sport TDV8 HSE Lux Sumatra Black
the same stuff as the Gtechniq but in a cheaper box is 'WipeNew'.
Always used the Gt stuff but found the wipenew when I was in America last year. Its exactly the same, smells the same and lasts forever. Plus its £10 on eBay! Thumbs Up
Post #493292 Mon Apr 11 2016 10:18am
adsymck
Thanks All.
I have heard some reveiws of the Forever product, but I think it all depends on application.
I think I'll be trying the WipeNew.
Post #493294 Mon Apr 11 2016 10:29am
Gerd1986
Think I will try wipenew next time I need to top up, certainly much cheaper than C4.
Post #493295 Mon Apr 11 2016 10:42am
Marcpope
United Kingdom 2007 Range Rover Sport TDV8 HSE Siberian Silver
Have you tried the old peanut butter trick? Works well mate
Post #495375 Sun May 08 2016 1:49am
Jimbob36
Fancy doing the same. Any pics of before and after?
Post #498401 Fri Jun 10 2016 9:34pm
adameverett
Had good results from the forever black. Tried various other types of black restorers they only seen to last weeks.
below is a few weeks after the last product I tried, you can see its quite patchy and going grey.
then I tried the forever black, pic after first coat.
I left a section unpainted so you can see the difference, several weeks in and still looking good. Tip is get the surface clean, they supply a bottle of cleaner but I also scrubbed it washed it scubbed it Wink . First attempt was streaky, I put it down to surface contaminates from the various other products I have tried. pic above is only 1 coat, I waited 24 hours and applied a second coat Very Happy
The product comes with a foam brush to apply, seems to go a long way, applies like painting in ink.
Also did the washer jets on the bumper, really please with result. Thumbs Up
Post #498405 Fri Jun 10 2016 10:08pm
CANROVER
Canada 2010 Range Rover Sport Supercharged Santorini Black
I have the same issue with the trim at the bottom of the front wind screen. Curious and want to try the peanut butter trick. To be honest I've heard great things about it but I'm not sure if it's effective enough for the trim mentioned above. Would anyone have some before and after pics of this method on the Front Windshield trim?
Post #499200 Wed Jun 22 2016 12:17pm
adameverett
I have tried a lot of different products, and read a lot on peanut butter. Its just oil it cannot restore and will wash off very quickly. There are vids on utube with peanut butter experiments, save your time. Wink
Post #499258 Thu Jun 23 2016 7:51am
edviss
United Kingdom 2006 Range Rover Sport TDV8 HSE Giverney Green
I have seen other people getting those trims professionaly wrapped.
Post #500501 Sun Jul 10 2016 10:12am
