![]() | Home > Detailing & Car Cleaning > Restoring plastic trim |
adsymck Member Since: 30 Mar 2016 Location: Fleetwood Posts: 8 ![]() ![]() ![]() |
Hi all,
Gerd1986 Member Since: 07 Oct 2015 Location: London Posts: 303 ![]() ![]() ![]() |
gtechniq c4 permanent trim restorer
Thanks Gerd1986.
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
I bought some of this:
Yup the C4 stuff, use sparingly though. A little goes a long way! |
Thanks All.
Think I will try wipenew next time I need to top up, certainly much cheaper than C4. |
Marcpope Member Since: 24 Mar 2016 Location: Southampton Posts: 4 ![]() ![]() ![]() |
Have you tried the old peanut butter trick? Works well mate |
Jimbob36 Member Since: 13 May 2016 Location: Melton mowbray Posts: 74 ![]() ![]() ![]() |
Fancy doing the same. Any pics of before and after? |
adameverett Member Since: 14 Nov 2015 Location: Warwick Posts: 110 ![]() ![]() ![]() |
Had good results from the forever black. Tried various other types of black restorers they only seen to last weeks.
then I tried the forever black, pic after first coat.
I left a section unpainted so you can see the difference, several weeks in and still looking good. Tip is get the surface clean, they supply a bottle of cleaner but I also scrubbed it washed it scubbed it ![]() ![]() The product comes with a foam brush to apply, seems to go a long way, applies like painting in ink. Also did the washer jets on the bumper, really please with result. ![]() |
CANROVER Member Since: 03 Oct 2015 Location: Ottawa Posts: 255 ![]() ![]() ![]() |
I have the same issue with the trim at the bottom of the front wind screen. Curious and want to try the peanut butter trick. To be honest I've heard great things about it but I'm not sure if it's effective enough for the trim mentioned above. Would anyone have some before and after pics of this method on the Front Windshield trim? |
I have tried a lot of different products, and read a lot on peanut butter. Its just oil it cannot restore and will wash off very quickly. There are vids on utube with peanut butter experiments, save your time. |
edviss Member Since: 29 Feb 2016 Location: london Posts: 28 ![]() ![]() ![]() |
I have seen other people getting those trims professionaly wrapped. |
